question about belt squeal
Old Jan 9, 2013 | 02:42 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Originally Posted by 2jznosht
Yaaay...time to spend more money. Na-t is never going to happen at this rate.
The tensioner belt pulley is not expensive at all. It cost's as low as $15.00...shouldn't be to bad to replace either. Easy in...easy out
Old Jan 9, 2013 | 04:08 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
so does the outside part of your a/c pulley spin, because it should be spinning.
Old Jan 9, 2013 | 04:32 PM
2jznosht's Avatar
2jznosht
I just mean in general, not the repair price... My other money pit is a 89 sec 560. Between the two needing crap done turbo is looking further and further away
Old Jan 9, 2013 | 04:56 PM
2jznosht's Avatar
2jznosht
Nope...if it warms up outside ill try and see if I can get it to move, but as it sits with the motor running it doesn't spin at all
Old Jan 14, 2013 | 02:26 PM
2jznosht's Avatar
2jznosht
Minor update...after a few treatments of wd40 penetrating the areas that should spin and then cleaning the area after last week the pulley spins as of today when I started it?could it be time for a tensioner pulley, or could all the noise be from the fact that its been below freezing for the last month and a half here?
Old Jan 16, 2013 | 11:21 AM
2jznosht's Avatar
2jznosht
Question...I was shopping and noticed that the pulley itself is roughly 15, but there is also an option of buying the full assembly for about 120. When these things go out and start making noise is it typically the fully itself or something in the assembly
Old Jan 16, 2013 | 11:25 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Most of the time it is the pulley bearings themselves. Anything else that makes any noise in the assembly should be corrected with WD-40 or liquid Wrench I would think...
Old Jan 16, 2013 | 11:59 AM
2jznosht's Avatar
2jznosht
Good to know...the cheaper the better.
Old Jan 16, 2013 | 12:01 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Not in all cases is cheaper better...I'd rather spend 10 grand on a used Lexus than a brand new Kia Rio. But in this case, cheaper IS better.
Old Jan 16, 2013 | 12:18 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
yeah if you managed to free it up just keep it well lubricated and hope for the best.
you would have to take it apart to replace the pulley, at that point it may just be the same to take it apart and clean the original one especially if it spins again without making noise. if it makes bad noises from that pulley specifically then a new pulley is in order
Old Jan 16, 2013 | 12:25 PM
2jznosht's Avatar
2jznosht
Touche. Shoulda said cheaper is better than buying un needed parts
Old Jan 16, 2013 | 01:36 PM
2jznosht's Avatar
2jznosht
So today with the car running everything spins, but the noise is loud. Guess it is the tension pulley
Old Jan 16, 2013 | 03:06 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
^^Most likely your tensioner pulley. I'd just buy the 15 buck pulley and replace it to get it done and over with.
yell0w
Apr 30, 2013 07:17 PM
azkaty
Jul 19, 2010 07:42 PM
sc300jas
Sep 10, 2009 08:56 PM
iamkhanz
Jul 15, 2009 07:30 AM
TMaxxTim
Aug 17, 2005 06:06 PM
