drifting ebrake shoes?
Old Dec 23, 2012 | 12:45 AM
89supra884's Avatar
89supra884
Default drifting ebrake shoes?
well i am going to be drifting my sc this summer, and i was wondering if there were any companies that make ebrake drift shoes. i know project mu does but i was just wondering if there were any other companies. i just replaced mine with oem shoes and no luck. also if you are not using drift ebrake shoes what and how is your ebrake system?.
thankyou
Old Dec 23, 2012 | 09:48 AM
Candela's Avatar
Candela
The Project mu shoes are just overpriced shoes. I hope you did a search, but even if you did I'm sure you found nothing about that on a forum like this.
You replaced your old worn shoes, so you're on the right track. What you're supposed to do is, adjust the shoes to a wider position, so that when you pull the ebrake lever, it'll bite harder and lock. If you want more info you should do a search on zilvia or my350z
Old Dec 23, 2012 | 10:32 AM
89supra884's Avatar
89supra884
Ill defiantly try to adjust them a little more. I didnt want to to it so tight that the wheel didnt move lol. But ill defiantly check those sites, I wanst surr if they used the smae ebrake setup.
Thankyou
Old Dec 23, 2012 | 10:45 AM
dengman's Avatar
dengman
have you tried adjust the cable at the lever?
Old Dec 23, 2012 | 11:05 AM
Candela's Avatar
Candela
^^ What he said, that also helps, there should be another point of cable ajustment on the bottom of the chassis. And what do you mean you don't want it too tight? You said drifting, so you want the ebrake to lock the rear wheels.
Or if you wanna go hard core, do a hydro ebrake
Old Dec 23, 2012 | 01:34 PM
89supra884's Avatar
89supra884
i wanna go hydro next year when funds are better, but ill defiantly look into that point of adjustment on the chassis! i did adjust it from the ebrake lever but i will go a little tighter on the shoes, lever and chassis!
thankyou
mr_mkelly
Nov 8, 2009 06:50 PM
passnu2
Chicago Lexus Club
15
Mar 23, 2009 07:54 PM
7826441
Florida Lexus Club
Feb 3, 2007 07:24 PM
ja8m1e6s
Nov 11, 2006 02:57 PM
