Got my Teins in today
AzLex,
how many clicks are you running in the front and rear with the HA? I"m going to install my tein CS pretty soon and was curious to what you adjusted yours to. kinda scared about the rear because my 9x9.5 rear might rub. sucks!
Originally posted by do-luck sc
AzLex,
AzLex,
-Steve
Originally posted by Manaray
Hey, what size tires are you running?
Are you sure you need to roll the fenders? You should be running a +38 and +42 (front/rear) setup...you should be able to lower it w/o rubbing...is it rubbing now (like when you hit dips or a speedbump or anything?)...if not, you won't need to roll the fenders....
Do you have some high resolution pictures of your car? Can you email me at GS430@mac.com if you do...thanks!
How do you like the ride on the HA's with the 18's?
Any future plans for the car?
Originally posted by AzLex
I have 3 threads left in the front and in the back they are set in the middle. That left me with about an inch of gap between the fender and top of the tire. I want to lower it more but I need to get the fenders rolled first.
-Steve
-Steve
AzLex - Thanks for the info...like Do-Luck said, you shouldn't rub at all...
Lowering it more just creates more negative camber...much like pushing it the front end down...
Compress your suspension so that the wheel tucks (push up and down on the car...be careful not to dent your fenders...), if it doesn't rub when you do this, then lowering it more will be ok...
HOWEVER, be careful when you have the car too low (like the front wheel tucked (rear wheel tuck is ok)...when you have the steering turned, and you hit a bump and if your car is too low, you have a VERY, VERY good chance of messing up your fender...
I've seen it a thousand times...
