Clutch Return Spring Problem?
Old Sep 8, 2012 | 05:38 PM
TheAzn's Avatar
TheAzn
Default Clutch Return Spring Problem?
Hi guys,
I just bought an SC300 with a 5 speed, nice! I have driven it for more than 200 miles now and I just encountered a simple problem not sure if it's a one time thing or whatever....
I was moving my Lex into the driveway and noticed the clutch pedal did not fully return. It usually sits at the same level as the brake pedal. But it sat at only halfway. I took a look under to see what was holding it from returning up, nothing. I pulled on the pedal a bit and it came up. So I sat in the seat to press and depress fully the clutch pedal to see if it gets stuck again, it doesn't (yet, maybe).
I saw what looks like a return spring on the assembly (resembles a small strut assembly). I was wondering if these goes weak over time or occasionally need a lubing. I'm assuming that would be the cause.
Old Sep 15, 2012 | 07:05 AM
murph4747's Avatar
murph4747
iv had the same problem for a while, i was once told it was my slave cylinder? I'm not exactly sure if it is or not, i just got used to pulling it up with my foot after a shift
Old Sep 15, 2012 | 10:27 AM
TheAzn's Avatar
TheAzn
Yep, basically what I do. I don't think it's holding and riding the clutch at least. I'll probably change the slave cylinder when I'm able to put my car on the lift to work on other minor issues. The fluid needs to be replaced, too. Looks dark for my liking.
Old Sep 17, 2012 | 06:55 PM
murph4747's Avatar
murph4747
yeah i have my motor and tranny out right now so I'm changing a few things around to see if it will go away when I'm done, but i won't know exactly what it is, but il give you a list of things that i changed when I'm done, and if it gets fixed when I'm done
estomax
May 18, 2013 03:00 PM
iduntnoega
Oct 10, 2009 08:13 AM
iduntnoega
Sep 21, 2009 02:50 PM
95 Integra
Dec 13, 2005 07:28 PM
kaotiq
Apr 28, 2003 06:56 AM
