Steering Wheel
Old Aug 30, 2012 | 11:44 AM
Farbound's Avatar
Farbound
Default Steering Wheel
Well my issue is that the little button that makes the steering wheel come out and in/ come up and down, won't make the steering wheel go down or up when I press down or up. Anyway I can fix this issue.
Old Aug 30, 2012 | 12:54 PM
- V -'s Avatar
- V -
Does it make any weird noises when you try to have it go up and down? Is the issue with only up and down or is it completely dead? you could have an issue with one of the gears out of place but you need to figure out if the motor is still working or not. If its working just follow this thread and youll be fine.
https://www.clublexus.com/forums/sc-...wheel-fix.html
Old Aug 30, 2012 | 01:08 PM
Teal Sc400's Avatar
Teal Sc400
Make sure the lock button is not push in/on. Located on the left side under the steering column. This will cause the feature not function.
Old Aug 30, 2012 | 02:50 PM
Farbound's Avatar
Farbound
Yes it does make a "errrrrrrrr"/weird noise when I try to make the steering go down or up. It comes out and goes in just fine.
Old Aug 30, 2012 | 03:59 PM
xxtoobsxx's Avatar
xxtoobsxx
There is a DIY fix with a rubber washer!
jay-b
Apr 10, 2015 07:12 AM
mark98ls40
RX - 1st Gen (1999-2003)
Jun 17, 2009 12:31 PM
islandsnow
Sep 2, 2006 10:24 AM
silversc3
Sep 28, 2003 06:10 AM
