IGNITION SWITCH REMOVAL!! Help!
Old Aug 28, 2012 | 02:18 AM
BenzKilla's Avatar
BenzKilla
Exclamation IGNITION SWITCH REMOVAL!! Help!
Can anyone direct me with a DIY ignition switch removal my key will not turn inside the switch I guess it's stuck fully I've done everything to try and make it work and am just going to replace it I need some help on how to remove the cut off bolt that holds the ignitio switch in
Old Aug 28, 2012 | 09:13 AM
93MSB's Avatar
93MSB
i used an air hammer with a small chisel, hit them at an angle going counter clock wise and they should start to come out
Old Aug 28, 2012 | 10:29 AM
Harbinger's Avatar
Harbinger
https://www.clublexus.com/forums/mai...need-help.html
Old Aug 28, 2012 | 11:05 AM
BenzKilla's Avatar
BenzKilla
Thank you!
Metlupass2
May 6, 2019 04:52 AM
dicer
Nov 19, 2014 10:48 AM
Firedup
GX - 1st Gen (2003-2009)
Oct 2, 2014 11:15 AM
vwynn
Nov 8, 2010 09:46 PM
evolon5150
Jun 5, 2003 02:56 PM
