ecu
Old Aug 8, 2012 | 09:49 AM
henesey05's Avatar
henesey05
Default ecu
Guys my baby will not run right. it smell of gas and has no power. is it my ecu? Please help
Old Aug 8, 2012 | 11:42 AM
henesey05's Avatar
henesey05
can anyone help?
Old Aug 8, 2012 | 01:28 PM
sj408's Avatar
sj408
Originally Posted by henesey05
can anyone help?
You need to be more descriptive.... Your basically saying "something is broken, be a mind reader and tell me what it is"
1. What is the difference in driveability?
2. Any check engine lights?
3. Up on current mantainence?
4. have any opinions given by a mechanic who has seen it in person yet??
5. At what point did you notice the problem arise, and did you do anything to the car differently before it started.
Old Aug 13, 2012 | 09:44 AM
henesey05's Avatar
henesey05
Well it started overnight. My check engine light popped on, then it became virtually powerless. It smells likegas, as if its flooding out. I have changed the complete gas line and filter from the tank to the motor. Plugs, and wires. I don't know what it could be. I bought a used ecu that matched up with mine. Once I installed the used onemy car would not start at all, so I put my original back and it started. Is it my ecu thats just bad?
Old Aug 13, 2012 | 10:11 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
First, try unplugging the MAF while it's idling and see what happens.
Also try resetting the ECU by disconnecting the negative battery cable and see if that does anything.
O2 sensors?
Coils?
Pull the codes and see what you can find....
Munch517
Mar 15, 2016 11:05 AM
lex1220
Aug 23, 2011 09:45 PM
MIGS
May 19, 2010 03:13 PM
bigbllr2000
Performance
Jun 8, 2002 10:21 AM
