Throttle Position Sensor
Old Aug 3, 2012 | 11:37 AM
Cranbery's Avatar
Cranbery
Default Throttle Position Sensor
Hey all. My TPS has gone bad and I looked up a little background on the repair. Looks simple enough, screw the old one off and new one on. The only part I'm not too confident on is the calibration of the sensor. Is it possible to buy one already calibrated? Or is it simple enough to calibrate with an OPDII? Thanks.
-Sebastian.
Old Aug 5, 2012 | 09:20 AM
durps's Avatar
durps
Only way I know of calibrating it is by getting a multimeter and tilting it in each direction until the proper resistance is being shown.
Old Aug 5, 2012 | 10:35 AM
Luxor's Avatar
Luxor
https://www.clublexus.com/forums/sc4...for-sc300.html
I am selling one for cheap if you are interested
Old Aug 5, 2012 | 10:40 AM
Luxor's Avatar
Luxor
I believe I calibrated mine by feel. Your idle will change as you turn the TPS and I turned the TPS when the idle felt normal again. But I highly recommend doing what derps said.
Old Aug 8, 2012 | 05:16 PM
Luxor's Avatar
Luxor
Let me know how the new TPS works out for you
philllyj
Jul 23, 2012 08:07 PM
Lexs400
Feb 18, 2005 08:43 AM
SCmist
Sep 14, 2003 11:17 PM
LB Lex
Maintenance
Jan 11, 2003 03:19 AM
