Is this right?
Old Jun 24, 2012 | 12:10 PM
Kayasith95's Avatar
Kayasith95
Default Is this right?
I have a stock 93 5speed and i was wondering.. is this right? apparently I red line at 100mph?? Just wondering if this is normal or my rpm is off or someone swapped the rear end? I feel like im killing a whole lot of gas. No this car wasnt manual swapped. It should be w58 and 4.08 ratio??
Old Jun 24, 2012 | 01:32 PM
4thHorsemn's Avatar
4thHorsemn
damn! no that ain't right, at the same speed in 5th mine is at 3000 rpms roughly.
Old Jun 24, 2012 | 01:39 PM
Kris9884's Avatar
Kris9884
Holy crap no. It's like you're in 3rd or something? Sucks man, time to swap a rear end it seems.
Rock on for the low miles though lol
Old Jun 24, 2012 | 03:59 PM
spacedog's Avatar
spacedog
what gear are you in?
Old Jun 24, 2012 | 04:33 PM
Kayasith95's Avatar
Kayasith95
lol this is 5th gear... I have no idea what the previous owner did to this
Old Jun 24, 2012 | 04:41 PM
uras300's Avatar
uras300
Redline at 5th gear should be around 145+mph on stock rear end + W58.
Old Jun 24, 2012 | 05:28 PM
iridebmx's Avatar
iridebmx
thats very close to having a 6.70 rear end! how the..... why the....?
W58:
1- 3.285
2- 1.894
3- 1.275
4- 1.000
5- 0.783
plug that in this excel sheet(bottom green box download it have fun with it) with 6.70 as the gear ratio for proof, evidence or what ever you wanna call it
http://www.diffsonline.com/techinfo/index.shtml
Old Jun 24, 2012 | 06:39 PM
Kayasith95's Avatar
Kayasith95
Well how is this even possible?? how could my speedometer be accurate if my differential is off so much anyway? Wouldn't changing the rear end effect my speedometer? I feel like im going to blow up every time im on the highway.
Old Jun 24, 2012 | 06:53 PM
iridebmx's Avatar
iridebmx
the speedometer is right, changing the gear ratio will not effect it as the speed sensors are still doing their job correctly.
it just seems like someone either messed up the transmission gears BADLY or somehow found a extremely high rear end gear ratio. this is quite odd haha.
how are gears 1-4, are they very very short?
your 5th gear right now is basically 3rd gear in a normal 5 speed SC300
Old Jun 24, 2012 | 07:00 PM
Kayasith95's Avatar
Kayasith95
All the gears feel normal everything feels normal only clicks into 3rd sometimes. maybe i need to check to see if my tach is right? if not then how do i reprogram it to read right?
Old Jun 24, 2012 | 07:04 PM
iridebmx's Avatar
iridebmx
you said the car feels like it's going to blow up on the highway.... are you saying that because the reading is so high or is the car actually revving that high?
i really hope the end of this thread doesn't end with you never shifting into 5th gear and going from 4th back to 3rd thinking your in 5th....
Old Jun 24, 2012 | 07:12 PM
Kayasith95's Avatar
Kayasith95
i meant i feel like im going to blow it up everytime i see it in the red. I'm getting the test light soon hopefully its just the tach thats off
Old Jun 24, 2012 | 07:28 PM
1WILLY1's Avatar
1WILLY1
forget what the tach says how does your car sound , is it really redlining or isd it a false reading from the tach?
And in my sc4 auto im around 2000rpm at highway cruising speed, 60mph/100kmh.
Something is very wrong, if its just your tach reading wrong then who cares, but idf your really redlining at highway speed u need to do something before u ruin ur engine.
Old Jun 24, 2012 | 07:54 PM
Kayasith95's Avatar
Kayasith95
okay crisis averted reved it to 4k but it was actually reading only about 2-3k. Anyone know how to fix this? I just hate seeing red.
Old Jun 24, 2012 | 08:33 PM
1WILLY1's Avatar
1WILLY1
your car was probably an auto before ive seen this on other threads, after the swap their tach readfs higher then usual
