Center Support Bearing
I ordered my Center Support Bearing from Lexus, it should be here tomorrow. How hard is it to replace? Is there anything special I should know other than marking how they are together now and put it back the same? Does the exhaust need to be removed?
On another note just serviced the transmission with rubber gasket and it leaks. I guess I should pick up a gasket from the dealer also, it leaks in one spot on the corner.
My alarm is super sensitive will go off if I am sitting in the car, any ideas. Driveshaft is the most important thing I need answered.
Thanks so much Alex. 93 Lexus SC300 automatic
Im curious as well since you havent even dropped the exhaust to check for play.
Where exactly is the tranny leaking from? Because i just recently dropped my automatic and saw that it was leaking where the rear end of the case meets the bulk of the case, so that it was leaking through the form in plqce gasket. Luckily im installing an r154 because it looks like a pita to tear apart the tranny just to be resealed
Goodluck
Charley
Goodluck
Charley
when i excellarate it bounces thumps where my emergency brake is. I have to slowly excell and then it smooths out. on freway it hums. i got it on ramps with a flash light and saw it was sagging
Luxor
Aug 14, 2022 02:25 PM
