HELP with control arm bushings
Subscribe
Jun 11, 2012 | 12:16 PM
I have a 97 sc400 that I'm trying to find lower control arm bushings for. Mine are worn completely out and the car is pretty sketchy to drive now. I have had absolutely NO luck getting emails returned from TM Engineering. Is there anyone else that makes these? I can't afford 400+ each for new control arms.
Reply 0
Jun 11, 2012 | 12:28 PM
Prothane makes a complete set for the SC300/400. I ordered a set from JEGS.com and installed them about a month ago. You can also get new control arms for Toyolex.com for around $300.00 each.
Reply 0
Jun 11, 2012 | 01:01 PM
you can get some oem ones from toyolex for right under $300
Reply 0
Jun 12, 2012 | 05:35 PM
Aren't Supra control arms cheaper (like $200) and have better performance?
I may be completely wrong, but I thought that was a common mod a lot of CL'ers do..
Reply 0
Jun 13, 2012 | 05:31 AM
you will not gain ANY performance from a lca.
i believe its pre 97' supras that are less expensive for the lca, but i would honestly just get the bushings. i just bought all of mine and for both sides it cost me around 65 dollars.
Reply 0
Jun 13, 2012 | 09:11 AM
+1 one the prothane kit from jegs, its cheap, the rear kit fits perfectly, the fronts fit but you have to trim the LCA, you'll know when you see it
Reply 0
Subscribe
