R154 front drive shaft
Old Jun 8, 2012 | 08:52 PM
2JTsc300's Avatar
2JTsc300
Default R154 front drive shaft
I'm about to swap my soarerr154 into my sc300. How do I take off the carrier bearing on my mkiii front driveshaft?
Old Jun 8, 2012 | 08:56 PM
LEXXIUM's Avatar
LEXXIUM
I think there are 2 or 4 bolts on the bottom of the carrier bearing holding it against the trany tunnel
Old Jun 9, 2012 | 11:01 AM
2JTsc300's Avatar
2JTsc300
I have the drive shaft out already. I'm trying to take the bearing off
Old Jun 9, 2012 | 12:04 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Some say the muffler/driveshaft shops do it for free or around 10 bucks. I dont know with basic tools, even tho I have never tried to take one off.
Old Jun 10, 2012 | 05:18 AM
Cleanshots's Avatar
Cleanshots
split the shaft front and back half.. if its already just the front half look on it it has a big nut on the end.. hit that with an impact then pull off the end. then take the drive-shaft and turn it upside down and tap it on the ground it will just fall off. then put on the sc carrier and reassemble. its straight forward and enjoy the r154, i know i do!
Old Jun 10, 2012 | 05:54 AM
INTIMAZY's Avatar
INTIMAZY
Just as an alternate idea, you can actually use the supra R154 carrier if your SC one looks miserable. I took a grinder to the R154 carrier tab that sticks out too high and dremeled the mounting holes a bit (ALOT!) and managed to massage the supra carrier inside our tunnel.
Visually it looks beefier than the SC one so I figured it must be stronger.
Old Jun 10, 2012 | 07:46 AM
2JTsc300's Avatar
2JTsc300
thanks, ill give that a try
GISguy
Jan 29, 2023 10:57 PM
KahnBB6
Jul 20, 2022 08:44 PM
Tory4
SC400 / 300 Classifieds
Oct 1, 2017 11:57 AM
charley240
Aug 7, 2012 02:23 PM
want sc300
Jan 15, 2010 06:21 AM
