Little help please with Crank Pulley!
Old May 27, 2012 | 07:41 PM
preston145's Avatar
preston145
Default Little help please with Crank Pulley!
Ok guys haven't posted in a bit and im having some slight trouble. My old harmonic balancer started to wobble a bit so i removed it and bought another crank pulley/balancer. Went to install it and im having two problems and i dont remember this being hard to install when i did my gates timing belt a little while back. When i do install the Crank pulley the woodruff key that aligns the pulley, it keep rasing up in the back its a pain and then, two is the pulley just suppose to slide on or do i need a press type tool to install the new pulley? please help im getting frustrated thanks so much.
Old May 27, 2012 | 11:05 PM
soarer13oy's Avatar
soarer13oy
Once you tighten the crank bolt it should go in. Usually its a bit harder because of little materials inside of the hold or on the crank. You can clean it and itll probably help.
bwils
Nov 21, 2022 05:04 PM
dashan
21
Mar 10, 2018 02:25 PM
STREETGS
Apr 13, 2016 08:36 AM
SC300_704
Mar 14, 2010 07:19 AM
