Misfiring under heavy load!!
Old May 27, 2012 | 09:25 AM
guku0701's Avatar
guku0701
Default Misfiring under heavy load!!
i have done alot of serched on this but couldnt come up with a proper solution so im posting it here..when i start the car i can hear a very slight miss..the other day i wanted to have some fun with the car and when i rev it to max it doesnt wanna go all the way up.misfires pretty bad when revved higher.but under 4k- 5k powerband it runs perfect.i have checked for vacuum leaks.,top ign coil has been replaced.i have also disconnected one coil to check other and my other coil performs the same as the new one.so far i have changed the spark plugs,wires,caps rotors etc..im waiting to change the fuel fiter as i found out its the original denso filter from the factory and thats kinda pretty old...does anyone have any other ideas?
Old May 27, 2012 | 09:48 AM
MrBrock's Avatar
MrBrock
If it's the original filter, it could be full of junk so replacing that may help. But a plugged filter will make your fuel pump work harder and it may also be failing. See what happens after you replace the filter.
Old May 27, 2012 | 10:10 AM
IanWatson's Avatar
IanWatson
I had the same issue with mine I have a SC400 don't know what yours is, but make sure the Fuel pressure regulator is working , thats what i had a problem with, after I checked everything .
Old May 27, 2012 | 04:07 PM
guku0701's Avatar
guku0701
ya i have a sc400 too..how do you know its working?and i heard theres 2 in this car?
thanks for the reply
Old May 27, 2012 | 04:08 PM
guku0701's Avatar
guku0701
i will look into changing the filter and see how things go..thanks for the reply
engin_ear
Performance
117
May 29, 2011 11:32 PM
Och
Jul 8, 2009 05:59 AM
trackball
Nov 29, 2007 06:50 AM
jimbo22s
Jul 1, 2004 08:16 AM
LB Lex
GS - 1st Gen (1993-1997)
Oct 19, 2002 10:24 PM
