ignition key dilemma
Old May 9, 2012 | 05:01 PM
MrNYSE's Avatar
MrNYSE
Default ignition key dilemma
Guys,
I have a problem, I just installed a new aftermarket radio and I was playing with the transmission lock. and now the key won't eject unless i disconnect the battery.
A few things to note:
I was installing the car radio with the car on. ( i know bad idea) trying to make the ground noise go away
theres a screw i was fooling around with making the instrument panel flicker (in the console)
Old May 9, 2012 | 05:12 PM
OG Dada's Avatar
OG Dada
The ground is for all instrument cluster, A/C, radio etc...
For aftermarket stereo, you need to by pass grounds because our SC's wiring were all built with 1 central ground point for each car electronic, here's a really good DIY to follow;
https://www.clublexus.com/forums/lex...ead-units.html
Old May 10, 2012 | 09:45 AM
MrNYSE's Avatar
MrNYSE
Thumbs up Issue resolved
ok so I figured out the problem so on the gear shifter theres a cap that slides down to expose the 2 screws. That cap was buried somewhere in the shifter. After digging it out it worked! Hopefully one day someone will find this as a solution
dantampa
21
Mar 29, 2020 03:33 PM
lexman52
Apr 16, 2019 05:42 AM
tentoys
Dec 7, 2011 08:57 PM
AJL0365
Apr 21, 2008 06:35 PM
brent0226
GX - 1st Gen (2003-2009)
Jul 20, 2003 10:24 AM
