Code 71-EGR system malfunction
Old May 6, 2012 | 09:45 AM
splacke's Avatar
splacke
Default Code 71-EGR system malfunction
I am having a problem with my '95 SC 300 and a pesky check engine light. It is coming up with a code 71 (EGR system malfunction). I have replaced the EGR valve and modulator. The light comes back on after about 50 miles of driving. I'm getting tired of the "guess and check" method. Could the EGR temperature sensor be the culprit? Any help is appreciated.
Old May 6, 2012 | 10:28 AM
GS4_Fiend's Avatar
GS4_Fiend
Check EGR temp sensor, EGR VSV and make sure the EGR passages are not clogged.
Old May 6, 2012 | 11:15 PM
CrazySC300's Avatar
CrazySC300
Holy smokes! I'm having the same exact problem with the same exact year model SC300 lol! I'll chime in once my problem is diagnosed,
Old May 6, 2012 | 11:27 PM
CrazySC300's Avatar
CrazySC300
I just had my egr valve and egr modulator replaced recently and just replaced my egr temp sensor as well yesterday...after about 50 miles of driving, I'll get that pesky check engine light as well (Which is also a code 71).
The valve and modulator tested out fine and the replacement temp sensor looked like it was in decent condition...all that's left is for me to try GS4_Fiend's testing methods,clean the clogged pipes and maybe replace the egr solenoid.
Old May 7, 2012 | 10:15 AM
sj408's Avatar
sj408
yeah i dealt with this issue forever, replaced egr valve twice replaced vacuum modulator twice. removed intake manifold cleaned all egr passages. Eventually i just removed the system and blocked off the passages + rerouted vacuum. Just gotta throw a resistor in whenever the check engine light actually starts bothering me
Old May 7, 2012 | 03:45 PM
GS4_Fiend's Avatar
GS4_Fiend
The EGR passages almost never gets clogged on the exhaust side(from EGR down to exhaust manifold). It get clogged on the intake side because temp difference from hot to cold. To determine if ur EGR passages are clogged on the intake side, apply vacuum to the EGR. D
Old May 7, 2012 | 03:47 PM
GS4_Fiend's Avatar
GS4_Fiend
The EGR passages almost never gets clogged on the exhaust side(from EGR down to exhaust manifold). It get clogged on the intake side because temp difference from hot to cold. To determine if ur EGR passages are clogged on the intake side, apply vacuum to the EGR and see if it stumbles alot, a little or nothing. If it doesnt stumble at all most likely you got clogged up EGR passages or a stuck closed EGR valve.
Old May 10, 2012 | 06:28 AM
splacke's Avatar
splacke
I believe my problem was the EGR temp sensor. I removed it and noticed it has some oxidation on the business end. After wire brushing the stuff off and doing a resistance check, it seems to be functioning properly. It has been 3 days and no check engine light.
Old May 11, 2012 | 01:33 PM
CrazySC300's Avatar
CrazySC300
I'm almost at a total loss here, My mechanic couldn't find anything that was clogged in the EGR system, The egr valve and egr modulator are both new units (Both were tested prior to being put on) My old torn egr temp sensor was replaced with a decent used one from a junkyard...All that's left is the egr solenoid which wasn't replaced at all, I'm taking my car in Monday to a guy who specialzes in smog repairs...This sucks!
Btw, How do you check resistance on the egr temp sensor?
Old May 11, 2012 | 01:35 PM
CrazySC300's Avatar
CrazySC300
Also, What did you mean by "Buisness end" on the egr temp sensor?
Old May 11, 2012 | 01:48 PM
GS4_Fiend's Avatar
GS4_Fiend
Why dont you just change the vsv yourself? Its not hard.
Old May 12, 2012 | 12:11 PM
splacke's Avatar
splacke
By business end, I mean the end that is screwed into the EGR valve. To check resistance, dip the tip into cooking oil and heat it up. The resistance should be between 69-89 Kohms at 122 degrees F, 12 to 15 kohms at 212 degrees F and 2 to 4 kohms at 302 degrees F.
Old May 13, 2012 | 03:32 AM
chargerfan's Avatar
chargerfan
^^^ has the cel gone away? im throwing hte same code and i too dont want to do the whole guess/check routine
Old May 13, 2012 | 09:48 PM
GS4_Fiend's Avatar
GS4_Fiend
read my previous posts.
Old May 24, 2012 | 06:03 AM
splacke's Avatar
splacke
An update: After cleaning the sensor, the light came back on after about 5 days. I figured that I was on the right track and possibly had a "lazy sensor". I bought a new one from Lexus, installed it and the light stayed off a couple of weeks. I thought I solved the problem, but the light came back on two days ago. Still stumped.
