Rough idle
Old Apr 23, 2012 | 03:15 AM
dtLS400's Avatar
dtLS400
Default Rough idle
My 92 sc300 5 speed has drained my battery and idles rough after I removed the interior carpet, seats, and. Center console. I plugged all the connectors as they were and I was able to start and drive the car after I put her back together, but when I tried to start her up the next day she would not start. Got a new battery and the car starts up but It has a hard time idling...
Old Apr 23, 2012 | 04:13 PM
GS4_Fiend's Avatar
GS4_Fiend
Check for vacuum leaks
Old Apr 30, 2012 | 03:20 AM
dtLS400's Avatar
dtLS400
I don't seem to see any vacuum leaks. My battery discharge light has come on the dash After I had the carpet out. The previous owner had
A
Few
Wires
Running into the trunk with nothing connected to it so I took those out, I also notice that my car does
Not have the stock amp if any, the previous owner installed
An aftermarket sound system and removed
Prior to sale with wiring still
There. My mechanic told me my alternator was not recharging battery. I'm going to check the fuses in theorning after I charge my battery a bit.
Old Apr 30, 2012 | 09:53 AM
GS4_Fiend's Avatar
GS4_Fiend
Bad charging system will indeed cause alot of problem. Also make sure ur battery can pass a load test or else that battery is NFG
Old May 7, 2012 | 09:46 AM
dtLS400's Avatar
dtLS400
Thanks for all the help guys. I found a frayed wire when I took my alternator off. One of the connector wires Into the alt was bad, saudered it up and taped it off problem is gone.
Booyah
GX - 1st Gen (2003-2009)
Jun 25, 2022 03:09 PM
rcolosi
Nov 12, 2017 09:47 PM
defrag010
May 4, 2009 08:54 PM
enycetony
Dec 12, 2007 07:59 PM
dkny_112
Sep 12, 2004 11:34 AM
