aem ems V2 for soarer, driftmotion !
Old Apr 9, 2012 | 05:33 AM
  #31
94_soarer's Avatar
94_soarer
ok so my only question with the dm 1jz aem v2 kit can i run low imp inj with a resistor box?
Old Apr 9, 2012 | 05:35 AM
  #32
bryan767's Avatar
bryan767
yep. ^
just cant run a auto transmission.
Old Apr 9, 2012 | 07:29 AM
  #33
cartmill's Avatar
cartmill
Originally Posted by Quicksc4
It's not the AEM my friend ...sorry
My 93 SC400 runs perfect with a 97SC300 2jzge engine in it the only thing i have to do is move the oil level sensor wire to a diffeent location but eveything works like stock.
okay, quick, do you have the driftmotion 1jz honda box and jumper harness that mark has?
Old Apr 9, 2012 | 08:01 AM
  #34
99SC42's Avatar
99SC42
QUOTE=meangreen1;7142433]Works great. I bought one last year and tuning was a snap[/QUOTE
Like i said it's not the AEM, Had AEM EMS in my car and the Only time i had issues was when i did the 12V mod.
You will get everything to work on that car if you jump couple of wires , no relay hard wiring is require.
1jz fires in batch, so why is only#1 cylinder is getting filled up with gasoline? Shouldn't it be 2 cylinders?
So even if it's seq why aren't the others cylinders full? The easiest thing to get your car running ON is an EMS because it tolerates alot of stuff , sensor etc...
Old Apr 9, 2012 | 11:40 AM
  #35
cartmill's Avatar
cartmill
it's not just the #1 cylinder.
Old Apr 9, 2012 | 11:58 AM
  #36
99SC42's Avatar
99SC42
^^^ Well mark told me #1 ,I still have the email that said #1 cylinder and that's what he over the phone when he had called me.
Ok so all the cylinders? i still don't think it's the AEM.
How about you guys undo all the relay that you guys have installed, And just jump the wires in the kick panel , undo 12V mod if there is any.
You should not have any gas in the cylinder.
Old Apr 9, 2012 | 01:45 PM
  #37
cartmill's Avatar
cartmill
anyone else actually use the DM aemv2 honda box on their car?
Old Apr 9, 2012 | 03:47 PM
  #38
DoomLight's Avatar
DoomLight
good question!
Old Apr 9, 2012 | 04:05 PM
  #39
99SC42's Avatar
99SC42
Originally Posted by DoomLight
good question!
there you go!
Old Apr 9, 2012 | 07:00 PM
  #40
DoomLight's Avatar
DoomLight
well that tears it. im going to buy one once i get enough cash in the bank.
a friend of mine is using a honda AEM V1 to run his SR20DET powered S14. so i mean there u go.
Old Apr 18, 2013 | 08:33 AM
  #41
hipnotizze's Avatar
hipnotizze
sorry for bumping a old thread but is any one running this a aem? any issues?
Old Apr 18, 2013 | 01:41 PM
  #42
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
No issues. I love it without ever looking back. Thanks for bumping thread... I have a Soarer 1JZ.
Old Apr 20, 2013 | 06:41 AM
  #43
DoomLight's Avatar
DoomLight
mine runs pretty good as well.
Old Nov 19, 2013 | 01:04 AM
  #44
jzs14's Avatar
jzs14
Hi guys, I found this thread when researching the driftmotion AEM V2 so I figured I would bump it up instead of making a new one. I just have a few questions before I go ahead and buy the AEM
1. Will the factory 1j MAP and IAT work well with this if I want to run around 25psi or do you guys recommend getting the AEM 3.5 bar map sensor. I currently run 19 psi on my hy35 with stock everything on a jzz30 ecu tuned on an afc neo and it runs fine without any fcd or anything so I am assuming the stock sensors are fine?
2. Will the stock coils and iginiter work with this standalone or do you have to rewire the coils?
3. And lastly my engine harness is a jzz30 harness that has a lot of unnecessary wires removed from it. We actually took it and depinned the ecu plugs to remove things like emissions, cruise control, auto tranny stuff, etc. Basically anything it doesn't really need. Do you think the standalone will function ok when plugged in to such a harness?
Old Nov 19, 2013 | 06:02 AM
  #45
99SC42's Avatar
99SC42
Get a 3.5bar and be done. get the gm iat sensor and weld iat bung on the ic and you're golden.
Yes, No you don't have to rewire.
and Yes ! You good to go.
