R154 Trans Issue.Help
Old Feb 11, 2012 | 09:25 AM
Catracho30's Avatar
Catracho30
Default R154 Trans Issue.Help
alright so i finished 5 speed swap r154.the issue im having is that it seems that the driveshaft part that inserts to the tranny is hitting the outer "CUP" metal that keeps the ds in balance i believe.i shaved down the driveshaft a bit but under high speeds it seems it flexes.i was wonder if i could just cut this piece off?im using a mk3 front half with my stock rear half.i also cut a slice on the cup to see if i can bend it.the screeching noise goes away at slow speeds but once i shift to fourth the screeching begins
Old Feb 11, 2012 | 10:17 AM
stockhatch's Avatar
stockhatch
Sounds like the tailshaft bushing may be worn. Do you have a fresh new tranny mount? How are the motor mounts?
Old Feb 11, 2012 | 04:06 PM
trancuongv's Avatar
trancuongv
I removed mines and everything is fine and dandy. No more screeching noise.
Old Feb 11, 2012 | 05:06 PM
99SC42's Avatar
99SC42
it's the dust shield just remove it , it makes an annoying noise ... it happen to me once where i was driving and the smoke was coming in the car , metal to metal contact.
remove the driveshaft and u can just pop the dust shield of the trans and re install the driveshaft and enjoy your car.
you can always buy a new one from toyota and reinstall it. the dust shield was bent from transportation
Old Feb 12, 2012 | 07:45 AM
Catracho30's Avatar
Catracho30
thank you very much sir.
TLsc300
Aug 7, 2013 04:53 PM
2JTsc300
May 31, 2013 05:23 AM
ArtZ
May 30, 2010 11:24 AM
mrshabo
Jun 21, 2006 01:56 PM
