Door wont close properly
Old Feb 12, 2012 | 07:07 PM
hihopes's Avatar
hihopes
ok so update on the door problem.. i think its got to do with the lock, but i need some help pinpointing it.
so when the door has this problem closing, if i go to lock the door it automatically unlocks (which is normal so you cant get locked out correct?) and the door will close fine after clicking the lock button on the door handle.
so my guess at this point is that the lock gets stuck somehow?
but here lies another problem.. once i click the lock button and get the door closed, the lock gets stuck and the door wont unlock unless i fiddle with it with the key from the outside.
so my guess is its got to do with the whole door lock, or maybe a particular part of it?
Old Feb 15, 2012 | 02:27 PM
hihopes's Avatar
hihopes
anybody with any insight or ideas to try and pinpoint the problem?
Old Feb 15, 2012 | 03:20 PM
88supramki's Avatar
88supramki
if you pull the handle prior to closing the door it will close properly right?
I have the same situation, it has to do with the metal rod and plastic piece that allow your door to close and open. pull the door panel and make sure to lube up that plastic joint, and make sure the metal rod isn't bent.
I'm just too lazy because my custom door panels weigh around 50lbs each
Old Feb 20, 2012 | 08:59 AM
SleeperTTz's Avatar
SleeperTTz
If lubing doesn't work, then go to a junk yard and look for a spare lock mechanism. The whole unit should be replaceable and you shouldn't have to change the lock cylinder.
Old Feb 20, 2012 | 09:53 PM
hihopes's Avatar
hihopes
i think this sounds like my problem. i didnt realize that pulling the handle fixed it, so i tried that and seems to be working... so far. when i get a chance ill take the panel off and check it.
Thanks !
Old Feb 20, 2012 | 09:54 PM
hihopes's Avatar
hihopes
alright cool, thatll be Plan B. Thanks for the help
SKStark
Nov 5, 2014 06:01 PM
charlescat
Aug 18, 2014 09:00 PM
Dai Kaiju
Mar 24, 2012 06:35 PM
TWISTED II
Jun 20, 2005 06:13 PM
gs4rocks
Oct 17, 2004 10:53 AM
