Pillow Ball Upper Mount feedback?
Old Jan 31, 2012 | 04:34 PM
INCLINEDI's Avatar
INCLINEDI
Default Pillow Ball Upper Mount feedback?
anybody on here know about these. will the jza80 work on sc??
TAKEN FROM SITE: "The CUSCO Pillow Ball Upper Mount is an adjustable camber plates that will replace the soft factory rubber upper strut mounts with high strength metal mounts and spherical (pillow ball) bushings. Cusco Pillow Ball Upper Mounts will allow you to adjust your front negative camber well over the factory specs for much better handling. Cusco Pillow Ball Upper Mounts offer a FULL range of camber adjustment but the maximum negative camber allowed for will depend on your entire setup, including ride height. They are designed to work with stock suspension or nearly every aftermarket system available"
http://www.rhdjapan.com/cusco-pillow...per-mount-9365
Old Feb 1, 2012 | 08:27 AM
TougeSC3's Avatar
TougeSC3
Nope. The JZZXX, and JZA80 chassis are very similar. The coilover isn't used to adjust anything other than height on these cars. Thos Cusco pillow ball mounts aren't made for the JZA80 of JZZXX.
turbon50
Suspension
May 4, 2011 05:08 AM
M1_ASPT1
Club Lexus Vendor Marketplace
Jul 23, 2008 01:29 PM
TheMole
SC400 / 300 Classifieds
Jul 21, 2007 10:57 AM
mrshabo
Oct 16, 2004 07:52 AM
GS4Will
Suspension and Brakes
Apr 4, 2003 12:28 AM
