na/t fuel management
Old Jan 14, 2012 | 08:07 AM
supraclay's Avatar
supraclay
Default na/t fuel management
What is the best and easiest piggy back to run on a na/t
Old Jan 14, 2012 | 11:44 AM
SC300_704's Avatar
SC300_704
map ecu 1, 2 or 3
Old Jan 14, 2012 | 12:24 PM
lookEVO's Avatar
lookEVO
Well best and easiest dont necessarily fit like that.
Im running an SAFC and i have no issues with my car, it only cost me free cuz I already had it (but they can be had for 100 bucks)
Map Ecu works great if you wanna spend the money and make the changes to run it.
Old Jan 14, 2012 | 01:33 PM
spoolxexo's Avatar
spoolxexo
Or, you could take the big boy route, lose the dizzy, gain coil-packs, and do either:
-GTE ECU and Harness
-MegaSquirt and Harness.
The factory air metering system on the NA with a turbo bolted up to it, is garbage.
Old Jan 15, 2012 | 10:45 AM
supraclay's Avatar
supraclay
what do you mean how can you use a gte wiring harness on a na-t? and what a bout using a lexus sc400 afm with 550cc injectors and a safc?
Old Jan 15, 2012 | 11:30 AM
spoolxexo's Avatar
spoolxexo
http://www.clubna-t.com/forums/showthread.php?t=5545
Enjoy!
Old Jan 15, 2012 | 01:06 PM
imDementeD's Avatar
imDementeD
if my plan goes accordingly, i think ill end up doing the gte ecu and map ecu together to get me where i want.
GTE ecu with the stock dizzy/igniter, rx7 550cc injectors since the stock gte is setup for 550's and map ecu to convert to a map based setup vs the usdm maf.
I dont know if this will work as i hope it does, but after reading a lot of info about going the gte ecu route, this seems like it would work pretty easily and cheap. I also plan to solder the back of the ecu vs changing wiring on the na harness in case it doesnt work like i expect it to.
Scuper300
Feb 5, 2015 09:14 AM
2jzcrazy
Feb 19, 2014 11:29 AM
JerySNdsky
IS F (2008-2014)
442
Nov 12, 2013 11:41 AM
SC51
Apr 14, 2010 04:10 PM
got_trd
Jul 28, 2005 09:57 AM
