GI: Poly bushings
If for any reason any of these bushings do not fit or you find that they will not work we will take them back no questions asked. We mostly would prefer the data to feedback to our application database.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Oh, gotcha Duke. Well there seems to be only one application on the rack bushings so that is the best data I have right now.
Mike
Mike
Unfortunately they only come in a complete set. If I break the set then I would need to find someone just interested in the other side. Frankly if the rubber on the clamshell has aged to the point of deterioration , both should be replaced.
Thanks for the feedback Stick3
I will be working on adding a full SC category on our site so I can post up the rest of the bushings soon.
__________________
For installation i was a little hesitant because i thought i would need to break out a press to get the new bushings in. However with some of the supplied grease and a little finesse i was able to get the new bushings in by hand. Trick is to get it in at an angle (see pic) and then press the other portion past the bushing's lip. After that it'll slide right in (provided you greased the rack prior to install).
Here are some comparison pics
can't wait for the rest of the bushings mike!
Finally a better pic of teh rear subframe bushings. Also one set is up on the site. If you order now and they are out it will be 2-3 weeks to fill the BO.
Mike
http://shopfigs.com/v1/index.php?rou...product_id=119
Mike
__________________
Mike
__________________
Mike,
The REAR subframe bushings offered covers all 4 pcs needed in the rear (2 fronts, 2 rears) for that price ? OR is it just for the front pair as they look like them based on posted pics above ?
The price above is just the front pair. I need to look at a subframe to figure out waht is need for the rear.
__________________
