Factory Offsets
Old Oct 19, 2002 | 09:03 AM
legendary's Avatar
legendary
thanks for your help everyone...just a few things
coming from the Acura side of the house, we had some limitations...
Our factory offset is +65mm, rims had to be a minimum of +42, optimum is +48mm - +50mm. Good luck finding a wheel that is of your taste and width in those offsets (read JDM wheels).
Suspension is limited as well - Coilovers that may be available would be from Ms Emerald, and that is the jIC Coilovers....problem with that is those are like always on backorder....only other option is Ground Control Coilovers, those sorry Eibach 1" drop, H + R, or Intrax and Suspension Techniques.
So, bare with me, just trying to learn the quirks and what not about this vehicle, picked mine up yesterday...it is awesome. it feels good to be able to put some meaty rubber and lips on my car without worrying too much about scrubbing, etc.
ok, more searching...
Old Oct 28, 2002 | 09:54 AM
rboorgu's Avatar
rboorgu
Default Wheel width
Pcmw,
The factory wheels are 7 in not 7.5. Maybe that's where your calculations are off. If you significantly change the offset from stock on the front, the steering can become "darty" because of the greater scrub radius, which I beleive is the distance from the center of a line drawn between the upper and lower ball joints and the center of the rim.
Raj
Old Oct 28, 2002 | 12:13 PM
pcmw's Avatar
pcmw
Raj,
That is why I gave a range of possible offsets.
However, according to all the info I read about the factory wheels.
"The SC300 stock wheels are 15x6.5 inches (all four), and the stock tires are Bridgestone Potenza RE940 215/60ZR15
The SC400 stock wheels are 16x7.5 inches (all four), and the stock tires are Bridgestone Potenza RE940 225/55ZR16 "
cut/paste from Lex400sc's faq
MW
Old Oct 28, 2002 | 11:38 PM
rboorgu's Avatar
rboorgu
Default Wheel width
Stamps in the spokes of my rims are as follows
Toyota
16x7JJ
50
Mine is 1992 though.
Raj
Old Oct 28, 2002 | 11:59 PM
xBlkGs430x's Avatar
xBlkGs430x
will these rims fit the lexus sc400 19 X 8.0 offset 45 in the front and 19 X 9.0 offset is 38, im thinking about getting them but not sure if they fit
Old Oct 29, 2002 | 12:24 AM
pcmw's Avatar
pcmw
yes....but the question with 19's is what size tire?
MW
Old Oct 29, 2002 | 01:17 AM
xBlkGs430x's Avatar
xBlkGs430x
im not sure on tiers yet, i was thinking to check with discount tiers or a local tier shop and look into my options, any ideas...
Old Oct 29, 2002 | 07:05 AM
legendary's Avatar
legendary
I am going with 245/35/19 f and 275/30/19 r
19x8 f 19x9 r
Old Nov 2, 2002 | 11:58 AM
London Bill's Avatar
London Bill
I note some confusion regarding the correct offset for SC/Soarer wheel rims.
Factory rims have +50mm Offset, this would be applicable to rims upto 8.5" width.
Fitting rims with less offset on the front will change the handling due to the increased track / altered scrub radius, many wheel shops can get close to optimum with +48mm or +45mm which should be fine but +50mm certainly is the correct offset.
The rears can go up to 10.5" (possibly 11") width, here you can drop the radius to +38mm to prevent hitting the wheel arches.
8UR911
Wheels, Tires & Brakes Forum
Apr 7, 2010 12:18 PM
akuma138
Chicago Lexus Club
May 10, 2009 11:11 PM
lawrenceO
Aug 6, 2006 07:15 PM
Blue98Gs3
Oct 25, 2004 04:57 PM
Kevin L
Sep 17, 2004 12:05 PM
