Engine problems
Old Nov 30, 2011 | 11:16 PM
jintei's Avatar
jintei
Sup guys?
Yes, I want to fix the car.
Good news, jacked the car up last night and took of the midpipe and found debris of cat's honeycomb. Took them out and no more rattling so for sure it's not a rod knock issue.
Reset the battery and the car still running rich. It idles but it sounds like the engine is only running on 4 cylinders.
I am guessing it's the coil packs. The o2 sensor on the driver side got bent a little bit due to the debris of cat.
My question is, should I replace the coils, o2 sensors, and cat and I should be fine?
How many coils are on a 92 SC400? How much is reasonable price for each?
As for cat, should I just leave it alone or get a new one? If I should get a new one, should I get the stock or aftermarket (any gains from aftermarket)?
Thanks for the help guys, I really appreciate it.
-David
Old Jan 4, 2012 | 12:26 PM
ScWift92's Avatar
ScWift92
hey i have a similar problem but my car is an sc300 and i have no check engine light nore makes any sounds but car does bog when i give it gas keep in mind its 27 degrees out and the cars idle on start up is 700rpm any clue guys?
SC93
Oct 3, 2021 02:33 AM
swegs430
Jul 9, 2012 06:28 PM
rembo
Feb 13, 2009 12:28 PM
azari
Nov 24, 2006 06:19 PM
Prost
Jul 7, 2005 08:17 AM
