Changing battery cable harness on 92 SC400
Old Nov 12, 2011 | 03:02 PM
dogwisper's Avatar
dogwisper
Default Changing battery cable harness on 92 SC400
Anyone ever change a battery cable harness on an SC400. The negative side looks easy enough but that positive side I traced to an area by the starter and found a black plastic box that the cable terminates into and can't figure out how to open it. I knew this shouldn''t be a terribly difficult job but this has got me stumped.
Old Feb 10, 2015 | 03:30 PM
g099521's Avatar
g099521
I am wanting to replace the cable, while replacing the starter (SC400). Can I use a generic cable from Autozone and how do I connect/replace under/in the fuse box?
Bumpin' the thread cause I didn't find anything when searching...
Old Feb 24, 2015 | 04:49 PM
dogwisper's Avatar
dogwisper
I actually have a complete battery cable harness which includes positive and negative cables from the battery to starter etc. I was going to do it while I changed the starter and replaced valve cover gaskets etc but t looked like it would be a real bear to get between the firewall and rear of the engine to where the cable connects to the starter. I would appreciate it if anyone else on the forum has any information on changing this out.
Old Feb 27, 2015 | 04:49 PM
bigwhite's Avatar
bigwhite
I know you have to pull the intake manifold to change the starter on an sc4.
Old Mar 30, 2015 | 02:03 PM
JerryGarci's Avatar
JerryGarci
Default battery cable harness
Take my advice, it's more work than you think. I had an issue with my harness and ended up pulling the whole engine to access the full harness.
Old Jun 5, 2024 | 02:55 PM
Pleasehelpme's Avatar
Pleasehelpme
7th Gear
Was it a pain to pull it out? I think I may have to go through this process
SCFactory
Aug 11, 2016 03:14 PM
Bott63
Maintenance
21
Dec 7, 2015 03:58 PM
kohlex
Sep 20, 2012 12:38 AM
cmh
Sep 10, 2011 07:18 PM
