A/C is leaking =( help
Old Nov 8, 2011 | 04:53 PM
Devor's Avatar
Devor
Exclamation A/C is leaking =( help
Hi Guys I went to get my AC recharged the other day and sure enough there was a leak in the compressor somewehere. From what I was told it could just be a washers is loose or a nut isnt tightened down all the way. Heres a picture of what I am talking about.[IMG]C:\Documents and Settings\SCA12408\My Documents\My Pictures\sc300[/IMG] There is a black wire with a nut on the end of it on the right side of the picture. I was told it was leaking through any1 have this problem before??? Hes a better pix at a different angle. You can see the black wire and the nut is lower then the resdt of the compressorC:\Documents and Settings\SCA12408\My Documents\My Pictures\sc300 Idk if it's a new rubber garment it needs or what??
Devor's Avatar
Devor
].[IMG]C:\Documents and Settings\SCA12408\My Documents\My Pictures\sc300[/IMG]
Old Nov 8, 2011 | 06:20 PM
mktbully's Avatar
mktbully
upload your pics to an online host (photobucket is what i use) once it's "online" then you can use the img tags. can't take images from your c: drive.
tunedis95
May 28, 2013 06:14 PM
FatBrian81
Jul 30, 2011 07:44 PM
brad11140
May 12, 2011 07:57 PM
