A/c suction discharge pipe cracked HELP
hey guys, so i ordered an a/c system from gazi and getting all together on my lexus when i charge the system it leaks from a small crack in the Small a/c hard line which i believe is called the suction discharge pipe.
My mechanic says the line is too small to weld but hes no welder, so i figured id ask you guys if it could be welded? or what are some suggestions.
we were thinking cutting it out and flaring the ends and using some type of hi pressure line in between.
what do you guys suggest?
if somebody has one for sale from when they removed their a/c id gladly buy it.
gpxluke
NX - 1st Gen (2015-2021)
Dec 7, 2016 10:03 PM
