Gas pedal loose fix
Old Sep 9, 2011 | 07:04 AM
cheez's Avatar
cheez
Default Gas pedal loose fix
Was there a thread that shows how to fix the looseness of the gas pedal? I can't find it
Old Sep 9, 2011 | 09:14 AM
turbodremz's Avatar
turbodremz
Like the bracket is loose? Pedal shifts left to right? or there is slack in the pedal?
If its slack, adjust the cable on the throttle body. If its the bracket, there are 2-10mm bolts on the right side of the pedal assembly, simply tighten them down.
Old Sep 9, 2011 | 04:56 PM
cheez's Avatar
cheez
No the pedal is pretty sturdy, but if u put ur foot on the gas, theres about an inch of play before u hit the throttle.
Old Sep 9, 2011 | 05:55 PM
turbodremz's Avatar
turbodremz
Then the cable needs to be tightened up. Not hard to do, 12mm or 14mm wrench. If you tighten it down all the way and there is still alot of slack, pick up a new cable. Wish I had a stock TB to show an example on how to tighten, but you will see the 2 nuts and the cable when you look at the TB.
Old Sep 9, 2011 | 06:32 PM
JJ823's Avatar
JJ823
Same thing happens with my clutch pedal. Is it a similar fix?
Old Sep 9, 2011 | 06:42 PM
turbodremz's Avatar
turbodremz
No, the clutch pedal is hydraulic, but will have some adjustment on the pushrod underneath the dash. Try bleeding the clutch first, if it doesnt help, try adjusting the pushrod.
Old Sep 9, 2011 | 06:58 PM
cheez's Avatar
cheez
I just changed my slave cylinder today, I had to pump the clutch for a while to get the pressure back in the pedal.
YODAONE
27
Jun 12, 2020 12:58 PM
dendenyc
Dec 3, 2015 05:05 PM
Luxor
Nov 11, 2010 12:36 PM
OPSBD
Aug 20, 2010 06:31 AM
lovemov
Aug 29, 2004 06:51 PM
