Transmission will not move in reverse
Old Sep 6, 2011 | 06:02 AM
pourSc's Avatar
pourSc
Default Transmission will not move in reverse
Whats guys. Well, The sc is giving me another problem. Why am I not surprised? I have a gte with automatic trans. I had to take harness out of the car, due to the worst wiring job ever done on a vehicle. Thanks to another member on this forum, I was able to get most of the problems solved. Now, I went out to the car to drive it, and the car with no engage into reverse.
Does the Ecu control the trans mission? Is so, are there any wires that I should be looking at to get it move in reverse?
IS there anything that I should be doing to get to move in reverse?
The car will shift into reverse, but will not move. I can shift into drive and the car will drive forward.
Before, I took the harness out of the car, the car would go into every gear and work. When putting it into gear, it would shift hard.
Old Sep 6, 2011 | 08:02 AM
pourSc's Avatar
pourSc
c'mon guys. Any ideas.
Old Sep 6, 2011 | 03:02 PM
MMCtuner's Avatar
MMCtuner
The ECU control the trans, idk if can be that harness mod/repair you made. Is the trans fluid at level?
Old Sep 6, 2011 | 07:45 PM
pourSc's Avatar
pourSc
I added fluid to the tranny. I am going to change the filter and change the fluid tomorrow
Bocatrip
Apr 8, 2017 03:34 PM
Deception
Jan 13, 2014 08:00 PM
usoff89
12
Oct 16, 2013 03:25 PM
O. L. T.
SC400 / 300 Classifieds
Nov 13, 2011 08:24 PM
sivikvtec
Performance
47
May 12, 2010 05:08 PM
