Fuel inlet hose gaskets?
Old Sep 1, 2011 | 07:06 AM
INTIMAZY's Avatar
INTIMAZY
Default Fuel inlet hose gaskets?
So apparently I managed to lose the gasket(s) that go on both sides of the fuel inlet banjo.
Any idea on part number/sizes? Are they both the same?
I remember them being copper when I took them off. Are they just a flat washer or were they those copper crush washers?
Thanks!
Old Sep 1, 2011 | 07:49 AM
LexusFTW's Avatar
LexusFTW
They are crush washers. Go to your local autoparts store and pick up a few assorted sizes in the HELP section or here is the part number:
90430-12026 GASKET(FOR FUEL PIPE SUPPORT) $1.15
Old Sep 1, 2011 | 08:01 AM
INTIMAZY's Avatar
INTIMAZY
Thanks!
I went to Autozone locally and they didn't have ANY copper crush washers!
Checking NAPA next.
Old Sep 1, 2011 | 09:14 AM
LexusFTW's Avatar
LexusFTW
Autozone should have had the gaskets. They're not behind the counter, they're in the HELP! section of the store.
Old Sep 1, 2011 | 09:30 AM
INTIMAZY's Avatar
INTIMAZY
I looked but couldn't find anything. Then I asked the guy behind the counter and he showed me regular steel washers.
Old Sep 1, 2011 | 10:14 PM
INTIMAZY's Avatar
INTIMAZY
Apparently the banjo bolt itself is screwed up and I need to find another solution. The copper washer wasn't seating evenly. Good time to bypass the fuel dampener?
Edit:
You can use banjo bolt crush washers from brake lines. They fit and seal fine.
sptrakesh
Aug 5, 2024 05:03 PM
Arcturus
Jul 27, 2018 06:48 PM
Hil
Sep 13, 2011 08:30 AM
6SOARER
Feb 15, 2011 03:24 PM
quikturbo
Mar 20, 2003 12:47 PM
