Removing the rear differential... it's stuck.
Old Sep 28, 2002 | 02:03 PM
Overclocker's Avatar
Overclocker
G35x - RWD/AWD goodness
CL Folding 500,000
Clint,
Sorry I didnt' make that clear, I didn't need to swap half shafts as my stock SC ones just fell into place and bolted right up. My dad also came up with the x/y imput/output idea and it seems to be around 3 and 3/4. We're going to try to remove the LSD's tripod and put the one from the stock diff on it. I'll let everybody know how it goes tomorrow.
So if the stock half shafts fit, there's a good chance it's the TT auto LSD with the 3.76?
Wolff
Old Sep 30, 2002 | 11:14 PM
Overclocker
CL Folding 500,000
Default Disaster
One word, disaster.
The car had been up on jack stands for over a week and I my dad and I finished it Sunday night. Needless to say it stoped working and Lexus of Lansing "won't work on modified cars." I told them the truth that I had worked on it and they were no help.
I'm at a crossroads guys, I can put it back to stock (which I don't don't really want to do) or keep working on it (but I need to find a competent supra or other shop). I would really like to speak with somebody who knows about this type of mod. If you could PM with a phone number or if you can post information that would be of help I would be eternally grateful.
Wolff
Old Oct 1, 2002 | 10:33 AM
wmulli's Avatar
wmulli
Default Removing the rear differential... it's stuck.
When you say "it's a disaster", that doesn't really describe what the problem is... Can you be a little more specific?
Old Oct 10, 2002 | 07:25 PM
JBrady's Avatar
JBrady
Hmmm... I thought the idea to swap the tripod sounded reasonable. Overclocker, what happened?
Also, reading from the Supra manual it lists the 6 speed as a 3.133 ratio with an 8.66" ring gear and the auto as a 3.769 ratio with a 7.87" ring gear.
Old Oct 10, 2002 | 07:28 PM
JBrady's Avatar
JBrady
Here is the link to the online Supra service manual
http://www.mkiv.com/specifications/ncf/ncf93/
Old Oct 10, 2002 | 07:35 PM
JBrady's Avatar
JBrady
Here is a cutaway of the differential
http://www.mkiv.com/specifications/ncf/ncf93/ncf158.jpg
Here is the ratios and specs
http://www.mkiv.com/specifications/ncf/ncf93/ncf156.jpg
Here is the 6 speed ratios
http://www.mkiv.com/specifications/ncf/ncf93/ncf124.jpg
Old Oct 10, 2002 | 07:44 PM
Overclocker
CL Folding 500,000
jbrady,
Thank you very much for the links, I didn't even know that info was out there.
The minor update is I got the flange on but didn't set it up properly. I drove it and it locked up, but got the SC400 service manual after the fact. It seems you have to torque everything just right and there is a crush sleeve inside that I should have replaced, but didn't.
I took both the stock and Supra differentials to Sound Performance in Chicago to have them work on it. They were very friendly and knowledgeable and feel they can fix it and put the flange on properly. I'll update everybody when the work is done.
Wolff
Old Oct 11, 2002 | 12:37 PM
Lvangundy
Guest
Posts: n/a
Wow, awesome project, but too bad so many problems.
Can't wait to hear about how it drives after!
Lee
Old Oct 11, 2002 | 01:01 PM
Hermosa's Avatar
Hermosa
This thread is important to me since my Supra TT Auto LSD is going in pretty soon. The difference for me, however, is that I am going to add the rear axles as well.
Old Oct 12, 2002 | 03:16 PM
JBrady's Avatar
JBrady
Wollf, glad to be of assistance. Found the info surfing. If only I could find the manuals for my 99 LS400... I could use an LSD but haven't seen ANYONE do it on my car. I have to believe that it uses the same components as the other HD Toyota stuff. My front brakes look exactly like Supra Turbo stuff, 12.6" rotors, big 4 piston calipers. One thing of interest is the gearing on the 98+ LS cars is 3.27 and the gearing on the 95-97 cars is listed as 3.62. If the carrier on the Supra is the same as the LS400s that would give these 2 ratios as available ring and pinion swaps on those wanting to improve over the 3.13 on the Supra Turbo. Now, Clint says it is already 3.27 but the 1993 manual says 3.13 so the actual ratio may be year specific.
The other interesting note is the size and ratio difference between the 6spds and automatics.
6spds, 3.133 ratio, 8.66" ring gear diameter
autos, 3.769 ratio, 7.87" ring gear diameter
Non turbos get the smaller ring gear with a higher ratio of 4.272 which could really wake up a NA SC400.
On high torque cars the 8.66 ring offers much more torque capacity as the pinion is larger as well as the ring.
Old Oct 12, 2002 | 07:42 PM
Lex Luthor's Avatar
Lex Luthor
6spd rear is always 3.13, you're right, Clint is wrong....
- Jon
Old Oct 13, 2002 | 02:18 PM
sc300tt's Avatar
sc300tt
Sorry Lex, but to my knowledge most of the supra 6spd rear ends are 3.27s. Initially in 93 they came as 3.13, but were chagned the next year to 3.27, but I have even seen some places listing the 93s as having 3.27s so I am not really sure what is correct. I have seen tons of conflicting info from different reputable sources.
Either way, the difference is minor and of little consequence anyways.
Old Oct 13, 2002 | 03:33 PM
Lex Luthor's Avatar
Lex Luthor
All the one's i've seen have been 3.13 I believe, but I did some checking also, and like you said there's a ton of conflicting info. You do seem to have gotten me and jbrady on this one CP, because i've been told the later years are 3.27, even though one of the local guys here has a '95 (i'm pretty sure that's the year) and swears he has 3.13's, next time he stops by i'll have to mark his driveshaft and check. Small difference between the two ratios, but it would be good to end the debate, since there's a couple discrepancies on SC auto and 5spd gearing also....
SC3 auto 7.87" 3.92
SC3 5spd 7.87" 4.08, Clint I think you said it was 4.27
SC4 auto 7.87" 3.92, you disagree though, right?
Supra auto 7.87" 3.76
Supra 6spd 8.66" 3.13 for 1993/ 3.27 for 1994-up apparently
OK, can we clear this up, those who know speak up....
- Jon
Old Oct 13, 2002 | 03:42 PM
sc300tt's Avatar
sc300tt
The only thing I see about your list that is wrong is the SC3 auto, which is a 4.27
Old Oct 13, 2002 | 06:45 PM
Lex Luthor's Avatar
Lex Luthor
Gotcha, never counted the teeth on the SC3 auto R&P, so i'm assuming you're right, sorry for doubting you CP ......
- Jon
