strut mount question
Old Jun 16, 2011 | 02:03 AM
parker770's Avatar
parker770
Default strut mount question
I've been chasing front end clunking for a while. LCAs, sway bar bushings, end links, steering rack and bushings have all been changed.
I have the front end apart waiting on a front shock, and was inspecting the strut/shock mount. The mount itself looks perfect, but the rubber isolator that fits between the mount and the strut tower seems compressed and worn in a spot.
Is this isolator sold seperately? All of the images I see of mounts do not appear to include this piece. Could a worn isolator cause clunking?
Old Jun 21, 2011 | 05:50 PM
scfou's Avatar
scfou
Do this first before you spend more $$ elsewhere. Make sure both front sway bar endlinks are tightened enough. There's 2 bolts on each endlink. Place the appropriate size allen key on and use a rachet to tighten the bolt. I've made this mistake before when replacing the endlinks. I thought I tightened them already but actually not enough. You can't move it with your hands either so don't bother. Let me know if this works.
GreggyG
GX - 1st Gen (2003-2009)
Apr 15, 2019 06:35 AM
Clays93SC4
Jul 13, 2018 07:56 PM
Eliaquim
Aug 9, 2014 06:55 AM
RA40
Maintenance
Mar 31, 2005 10:53 PM
