EMS question
ok as some of you know i been having a problem with my ems, well i just found out the AEM EMS v2 i have is part # 30-6101 which is the sc300 and supra NA. I have a 2jzgte with a single turbo. would this have any effect on me having a NA EMS and me having a 2jzgte??
I'm not totally familiar with the V2, but I think your bigger consideration is in regards to which wiring harness you have in your car. I expect that either EMS will ultimately work with either harness, but there may be a few wiring changes necessary (as with the V1).
true. im just having some problems with boost and running rich as hell, just trying to cancel everything before i take it to another tuner so i have it already to go for the shop and not get screwd over again
The problem isn't necessarily which box you have, it's which CAL file initially was used for your tune. You need to make sure the 6100 GTE CAL file was used, not the 6101 cal file which is for a GE, the sensors and configuration are different.
YoshiFD3S
SC400 / 300 Classifieds
Jan 6, 2012 05:22 PM
