cigarette lighter problem?
Old Apr 19, 2011 | 02:54 PM
pwsc400's Avatar
pwsc400
Default cigarette lighter problem?
ok I am having trouble gettin my cigarette lighter to work, I checked the fuse and it was good, then i took the center console apart and looked to see if any wires were disconnected and they werent and I didnt see where anybody has messed with any wires at all.. whats the problem? I am thinkin maybe its a bad lighter to begin with idk any suggestions?
Old Apr 19, 2011 | 03:04 PM
booga's Avatar
booga
did you see any corrosion at the bottom of the lighter? Mine had a small wire which looked like it was in bad shape. I replaced the lighter assembly with bought parts from Vatozone and it has worked perfectly since.
$10 fix
Old Apr 19, 2011 | 03:07 PM
pwsc400's Avatar
pwsc400
yea i looked and i didnt see anything wrong with it looked brand new but maybe i will have to look into that thanks man
Old Apr 19, 2011 | 03:13 PM
booga's Avatar
booga
Round plastic piece had a small wires which had the rubber insulator brittle, and the copper wire was a little green.
Old Apr 19, 2011 | 03:24 PM
pwsc400's Avatar
pwsc400
oh ok so u basically just changed out the factory lighter with an aftermarket one and everything was ok from there?
Old Apr 19, 2011 | 04:25 PM
booga's Avatar
booga
after seeing the corroded wire, my original plan was to get the after market and use it as a donor for my existing lighter. But as it turned out the pieces were different enough and I damaged some pieces from the original lighter that I could not go ahead with the donor idea. So instead I did replace it.
Before doing this, I searched all over this forum and even created a thread for my questions. There were posts about fuses, and wiring, etc. But in the end, my case was that the lighter was just broken.
Now I can charge the phone and the iPod - Woohoo!!!
Old Apr 19, 2011 | 04:50 PM
pwsc400's Avatar
pwsc400
Good for you man good to hear u got it goin..i think thats what's wrong with mine just need to get another lighter and hopefully it will be alright
IneednSC
Feb 19, 2014 02:01 PM
thelopez
Sep 20, 2013 04:13 PM
got56ry
Sep 11, 2008 02:06 PM
Goosesedan
Dec 19, 2007 07:35 PM
bill
Dec 10, 2002 09:49 AM
