No Code But no power
Old Apr 2, 2011 | 12:30 PM
Halient's Avatar
Halient
Default No Code But no power
I am having an odd issue and usually I would take a look and see what the code is and resolve it but no code or check engine light.
Overall
I start the car it idles fine no odd noises everything seems fine, it has just had a tune up (new plugs, wires, distributor, cap, rotor, fanbelt and new o2's within 1k miles) since this issue started and timing is spot on.
I back the car up and its fine, when i put it in gear i have no power to go forward. I checked under the car and there are no leaks, Checked the fluid levels and all perfect and the oil and coolant are both clean
Any Ideas What this could be?
Old Apr 2, 2011 | 01:10 PM
6SOARER's Avatar
6SOARER
Does it feel like theres a misfire or just no power? Are the wires hooked up correctly? Pull your plugs to see if there not drenched in oil.
Old Apr 2, 2011 | 02:30 PM
Halient's Avatar
Halient
Before it had a bad valve cover gasket so there was some oil on the top of the plug but nothing on the electrode area, but now the plugs are perfect and clean.There is no misfire so im starting to think it could be a fuel issue since its fine at idle but not under load but there is still the oddity that reverse is fine.
jckol
Dec 7, 2016 06:08 PM
lilninja
May 4, 2012 07:33 PM
02msmg3
Performance
Nov 27, 2010 02:54 PM
xzeus
Aug 24, 2009 02:47 AM
