Lower Temp. Thermostat not working?
Old Mar 28, 2011 | 03:49 PM
SC300_704's Avatar
SC300_704
Default Lower Temp. Thermostat not working?
i know the oem thermostats operating temp. is at 180 F but i recently replaced it w/ an 170 F, but instead of staying at 170 F at normal operating temp, it goes up to 185 F or so...can this be a defective thermostat? btw when i installed the new one i did notice that it wasn't a tight fit as the original one but i don't think that would be the problem. i can tell the temp b/c i have a Autometer temp. sensor sandwiched between the radiator hose.
Old Mar 28, 2011 | 08:40 PM
BartleDoo's Avatar
BartleDoo
If your cooling system is not efficient enough to run at the temperature the thermostat opens at, then it will not stay at that temperature. If you increased the cooling system's effectiveness a good bit then you could get it to plateau at around the stat's opening temp.
Old Mar 31, 2011 | 06:33 PM
SC300_704's Avatar
SC300_704
ok problem solved. damn Autozone employee ordered me the oem temp. one instead of the 170 degree. all good now.
Calliope
Mar 16, 2017 06:04 AM
RedSC
GS - 1st Gen (1993-1997)
Sep 8, 2010 07:37 AM
Och
73
Nov 3, 2009 06:58 PM
mjes300
Aug 5, 2009 05:40 PM
