View Poll Results: How reliable is your swapped SC300 (doesn't matter if it is a 1JZ or a 2JZ)?
The car has run perfectly from day one.
47.37%
I had a few hiccups but no additional down time after swapping.
21.05%
Car has had some issues that led to extra breakdowns/downtime.
21.05%
Swap has been a disaster from the get get.
10.53%
Voters: 19. You may not vote on this poll
How reliable is your swapped SC300?
Old Mar 20, 2011 | 09:58 PM
1WILLY1's Avatar
1WILLY1
Originally Posted by StiCk3
i did take a gamble and i guess i got the bad one of the draw. Also some problems on my part like a bad clutch choice and a few minor oil leaks held me back. Im still in the process of getting my car to 100% but time and money are not helping. To each their own...
yes ive seen a bit of your other thread and i can tell your having a few issues---hopefully things are going to work
im sure they will--just may take some time and pateince------oh and a bit of money of course lol
good luck
Old Mar 20, 2011 | 10:52 PM
Superjatt's Avatar
Superjatt
Originally Posted by ClearP
... used engine is like wearing a used condom...
I wana keep this as my sig, you think itd be okay?
Old Mar 21, 2011 | 12:05 AM
gijohnnyb's Avatar
gijohnnyb
I think what you should ask is how many people who have swapped an engine did maintenance on their engine before the swap. Dropping a used engine is like wearing a used condom, I guess it would work, but it's an expensive gamble.
That is a great question. My other option is for me to purchase a 300 in good running condition, spending a little more on the car itself and then purchasing the motor and giving it a thorough overhaul while its out and I am driving around. This will buy me time and take off a lot of stress as well as reduce the chances of any unexpected and inconvienient down time after the motor is in.
Old Mar 21, 2011 | 12:39 AM
ScBouncE's Avatar
ScBouncE
Originally Posted by Superjatt
Well, its KINDA my fault , but basically I have had 2 1jzgte motors and have only driving 1, and not all that powerfully, right now I have no idea how the vaccuming goes and my motor doesnt feel like my buddies 1j, mines all laggy and bleh!
Im so glad you made this thread I finally let out my frustration lol
WINNING
lmao good **** bro
Old Mar 21, 2011 | 01:22 AM
account2x's Avatar
account2x
Define overhaul? I define overhauling as replacing the piston seals which would also require replacing every gasket and seal on the engine. Now this isn't necessarily a bad idea but it is a lot of work. The real question is it necessary? Considering more than a few members have over 200k engines on stock block I say no.
The oil pan gasket is the only other thing that can not be replaced with the engine still inside the vehicle.
If it was me I would first determine the condition of the engine you receive. Only after that can you decide what maintenance should be done.
Old Mar 21, 2011 | 01:23 AM
eliteskill's Avatar
eliteskill
My swap was flawless. Used mostly USDM parts and everything works like factory. Daily driven no problems at all. Did a 350 mile trip a few months ago. Still strong!
Old Mar 21, 2011 | 03:06 AM
gijohnnyb's Avatar
gijohnnyb
I define overhaul as replacing whatever is necessary to getting the motor in perfect working condition. I would like to avoid replacing pistons or tearing into the motor at all if possible. Just things like timing belt, water pump, rear main seal, etc etc...maybe headgasket but if I can avoid it I would like to.
Old Mar 21, 2011 | 06:31 AM
Triple C's Avatar
Triple C
I just spun a bearing in my 1Jz but my other 1J supra Motor is just fine and survived a track accident. Now i am swapping my 1J's and should have most of everything back in order before my next drift event. i am also adding a HX35 and Single setup so it should be fun and interesting
Old Mar 21, 2011 | 06:34 AM
trufanatic's Avatar
trufanatic
I have a 2j swapped sc400 and i drive it daily.
Old Mar 21, 2011 | 06:59 AM
soarer13oy's Avatar
soarer13oy
2jz swapped sc300 daily. Drives perfectly fine, but gotta fix ac and cruise control. I had very minor issues at the beginning, but its all fixed. I wouldnt think twice about reliabilty if i wanted to take it for a small trip. I have no regrets doing the swap as our cars need the extra power to get the thing moving. I also get about the same mpg as stock as long as i dont boost it too often.
Old Mar 21, 2011 | 10:17 AM
meangreen1's Avatar
meangreen1
LOL maybe..
Old Mar 21, 2011 | 10:45 AM
ClearP's Avatar
ClearP
Go for it! lol
True, people are running around with 200k miles, but there are also many people with engine problem before that, it's all about how you maintain the engine, I'll bet that people who are running high mileage engine are treating it properly too, the question is, when you buy an engine crated from Japan, do you know how it was treated?
Overhaul to me is taking things apart, replacing what NEEDS to be replaced. I'm doing that right now with my gte swap, it's going to take me a lot of time and money and it has already, but in the end, it's worth it for me knowing the engine is healthy and will go for another 300k under my watch.
Old Mar 21, 2011 | 12:10 PM
durtysc300's Avatar
durtysc300
I don't think I'd go swapped, but instead pull my current engine and completely rebuild it and go NA-T.
Old Mar 21, 2011 | 12:24 PM
RyanV's Avatar
RyanV
Originally Posted by eliteskill
My swap was flawless. Used mostly OEM parts and everything works like factory. Daily driven no problems at all. 200 miles a week, at least.
My only mistake was the cheap rebuilt driftmotion power steering pump x2...I found a used OEM PS pump and it has been good to go ever since.
Old Mar 21, 2011 | 03:06 PM
aka paco's Avatar
aka paco
Thanks for the replies so far.
I made this thread because it is very important to me that I don't have a tempermental car when I get back from Afghan. I will rely on it to get me to and from work and I will be driving it back and forth from TN to FL a few times a year at least.
I have to admit that after what I am hearing so far, I am kind of considering buying something else as a daily driver and building an SC300 on the side as I save the money for it.
I've had swapped cars that where dailys and ran like champs.. i've also had cars with stock engines that where very un-reliable..
