Missing Vac lines
Old Mar 15, 2011 | 07:06 PM
Halient's Avatar
Halient
Default Missing Vac lines
Long Story Short, I sent my car into a "Toyota-Lexus Specialist" for some maintenance work since I didnt have time to do it myself (50+ Hour weeks)
Car 95 Sc300
Work to be done
Plugs, Wires, Ignition Rotor, Distributor Cap, Thermostat, Flush and Fill Radiator, and Valve Cover Gaskets
I supplied all of the Parts but they "forgot" to use the OEM Manifold gasket and instead used some sort of silicone so I am not that confident in their work.
After about 6 days I get a call saying that "We finished up but now we think that the head gasket is blown and it will be another $1900 to fix " I immediately run down to see wtf since i had a compression check less then 10K miles ago and everything was perfect.
I checked both oil and coolant and they are fine, so i said screw it and had the car towed home (i attempted to drive it across the parking lot but it felt like it had a major miss and id rather be safe then sorry)
I opened the hood up today and found the vac port on the front driver side in front of the intake manifold was broken and on the rear there are open ports but no hoses that i can find for them.
I searched and was unable to find the proper routing of where the missing hoses go and come from so if anyone can enlighten me on the issue that would be awesome.
Broken Connector (If anyone knows the toyota Part # that would be great)
Rear where im missing lines (Ill take more pics tomorrow afterwork since I doubt that the bottom lines are correct)
Old Mar 15, 2011 | 07:13 PM
broda805's Avatar
broda805
look at the vacuum diagram right under the hood latch hood on the hood itself
Old Mar 15, 2011 | 07:17 PM
Halient's Avatar
Halient
Mine is missing so is my book
Old Mar 15, 2011 | 08:16 PM
broda805's Avatar
broda805
heres a quick pic i took with my cell phone i dont know if its good enough to use maybe someone else has a better pic or better camera.. lol
Old Mar 15, 2011 | 08:29 PM
broda805's Avatar
broda805
i think mines has california emissions mumbo jumbo so yours might differ slightly...
Fvneral
May 7, 2017 11:09 PM
zrs6v4
Apr 16, 2017 06:19 PM
911LE
May 10, 2016 05:18 PM
qmanlexus2
Dec 24, 2014 04:18 PM
DIYsquirre
Oct 15, 2006 01:44 PM
