Changing spark plug ????
How do i change the plug? There is no way to get anything in there to get the plug out ???? Is there any easy way without dissembly the whole thingy that get in the way?
Anyone changing plug yourself? How do you do it?
Thanks
Thanks
hmm I think you need to take out engine cover. if you have correct tools, it should be easy. I remember I had hard to change the one on the way back of left. but you can do it
good luck.
good luck.
bigmonkey....You have to remove the throttle body,cables and vacuum lines to access the plugs. Its a job you could do yourself if you have a good set of tools and mark all of the lines before you remove them. You might want to look into a service manual. Good Luck.
gadgetSC
gadgetSC
jpv7774
Jun 26, 2015 01:02 PM
