Prep calipers for paint? how should i?
Old Mar 10, 2011 | 01:34 PM
iridebmx's Avatar
iridebmx
Default Prep calipers for paint? how should i?
Whats the best way to prep brake calipers for paint?
I just got some ls400 brakes that i wanna paint!
Old Mar 10, 2011 | 01:46 PM
SChema's Avatar
SChema
I disassembled them soaked them overnight in a water and dish soap. Cleaned the major dirt and grit with a toothbrush. Removed any contaminants, such as oil with alcohol and let it dry before laying down the base coat.
4 Coats of base and 3 coats of clear using engine enamel.
Old Mar 10, 2011 | 03:10 PM
t70 supra's Avatar
t70 supra
wrong
1 use a small DA sand to bear metal then use acid edge primer then paint and clear coat and assemble
Old Mar 10, 2011 | 03:14 PM
TougeSC3's Avatar
TougeSC3
Originally Posted by t70 supra
wrong
+1 with what Cam said. Make sure you use a high temp paint.
Old Mar 10, 2011 | 04:50 PM
SChema's Avatar
SChema
wrong
Worked for me on several occasions. Mine was already bare metal so others may have to remove paint; therefore, adding a step. Haven't had any issues with the paint chipping and such. Been about two years on one car and four on another.
Many solutions to a single problem.
Old Mar 10, 2011 | 05:50 PM
iridebmx's Avatar
iridebmx
thank you!!!!!!!!
Old Mar 10, 2011 | 06:22 PM
Luxor's Avatar
Luxor
The best way? Sandblasting. Here is what sandblasting can do
Attached Thumbnails Prep calipers for paint? how should i?-ls400brakessandblasted.jpg
Old Mar 10, 2011 | 06:31 PM
xknowonex's Avatar
xknowonex
Here is a write-up on my Rotoras getting painted
https://www.clublexus.com/forums/sc-...k-project.html
Prepping is everything
1. Go to Wal-Mart, buy both a jumbo wire brush and a small one
2. Together with a few cans of brake cleaner, use the wire brushes to take off the old finish
3. Cover the holes and wash it off w soap and water
4. Let it air dry
5. Plug the holes w towel and mask off the pistons
6. Spray it with primer (preferably one from an auto body supply shop)
7. Spray with color of choice. Any paint from Home Depot or AUtozone
8. Spray clear coat (preferably one from an auto body supply shop, like Transtar Quik Clear)
9. Let it cure for a week or so.
10. Wax it.
11. Tape it up to protect it agaisnt scratches during install
Old Mar 10, 2011 | 06:35 PM
xknowonex's Avatar
xknowonex
Actually, the whole thing is about "high temp" paint for calipers is sort of a marketing thing.
The brake caliper unit itself doesn't get very hot, especially a non-floating one. Regular car paint lasts just fine like everything else, if not more durable.
Old Mar 10, 2011 | 07:02 PM
iridebmx's Avatar
iridebmx
Thank you all.
I think I am going to get a wire cup wheel to get the top layer off
also to rebuild the caliper what do i need to buy? i am seeing repair kits for like $5 for one side or am i looking for the wrong thing?
Old Mar 11, 2011 | 01:08 PM
iridebmx's Avatar
iridebmx
decided not to be lazy and raw the front of the calipers today, i may just paint the front and leave the OG coat on the back.
i went and bought a cheap craftsman evolv corded drill and got a fine wire wheel and went to town for like 30mins and got them pretty rawed. now time to choose a color!
btw i weighed them! 8.8 pounds each(no pads or hardware, just pistons and all seals) in case someone didn't know even though that info is probably floating around somewhere.
Old Mar 11, 2011 | 04:42 PM
kraven9's Avatar
kraven9
^^Those look good.
Old Mar 11, 2011 | 05:23 PM
iridebmx's Avatar
iridebmx
why thank you!
i decided I wanted to be impatient and just bought the duplicolor caliper kit thingy and this here is the first coat. im going to do a coat a day for like 5 days (rotors wont be in until next week anyway)
im hoping they turn out glossy-ish by the end....
Old Mar 11, 2011 | 05:26 PM
Luxor's Avatar
Luxor
why thank you!
Looks good!
Old Mar 18, 2011 | 01:04 AM
socal72's Avatar
socal72
Looks good! Heres a before and after of what I did yesterday check it out tell me what you think:
