My build thread killing an mkiv tt 6speed, to give life to my sc300
is it a one or two stage paint?
Did you spray a base coat and than a clear over it?
thanks and looking good
whaaaat you guys cant use laquer in the states ouch yea its base black and i put 5 layers of urethane laquer, car is goin to look like its made out of glass
ill keep you guys posted it should get interesting pretty soon motor should be goin in this week then gota install the flying lead harness for the haltech platinum sport 2k, then custom alum intercooler pipes and gota make a custom exhaust then cut and weld the drive shaft then balance it, oh yea then install the clutch pedal and master which i took off the mkiv, man after laying it all out like that makes me kinda lazy, then when i sell the mkiv shell i gota take her all apart again hehehe fun well gnight guys
Regan Jackson
ps does any 1 know how much the stock sc300 rearend/axles holds powerwise want to know if im goin to break anything at 800rwhp cant seem to find any info
ill keep you guys posted it should get interesting pretty soon motor should be goin in this week then gota install the flying lead harness for the haltech platinum sport 2k, then custom alum intercooler pipes and gota make a custom exhaust then cut and weld the drive shaft then balance it, oh yea then install the clutch pedal and master which i took off the mkiv, man after laying it all out like that makes me kinda lazy, then when i sell the mkiv shell i gota take her all apart again hehehe fun well gnight guysRegan Jackson
they have done the same with house paints---and also furniture finishes and the sort.
here it is guys finally got the car out of the booth got it ready for the install and finally got it installed heres the play by play heheh oh and my big problem that the end lets see what you guys think
and heres my problem the getrag doesnt fit inside the tunnell i was tihnking of puting a 3/4 inch spacer on the crossmember i really dont want to cut open the tunnel
Yeah, I also read somewhere that only the last couple of model year SC300/400/Soarers had a transmission tunnel capable of fitting the Getrag transmission with no modification. Supposedly most model years require you to physically "modify" the transmission tunnel for fitment.
That looks awesome!
