SC400 spitting, sputtering, engine shaking, no power
Old Feb 25, 2011 | 05:29 PM
  #31
brad11140's Avatar
brad11140
Originally Posted by 1WILLY1
brad ive had a long standing issue with me engine cel---------when i turn the acc on of course all the lights fire up---and than all the lights turn off---except my engine light-------it stays on indefinitely---but when i start the car the enging light turns off-------------does this mean the ecu is acting up?please elbarate if you can thanks
***** I really wish I could speak from expierence. At one point I suspected my ECU, but found a couple of posts on here that alluded to the fact that if your CEl fires when you turn the key on than your ECU is communicating. It should stay on briefly after starting than go off. But I beelieve mine stays on if I leave the key in the ACC position. Ill go check right now.
Old Feb 25, 2011 | 05:32 PM
  #32
brad11140's Avatar
brad11140
Yep, with the key in just the on position my check engine light is on. As soon as I fire it up, it goes out. Thats what you are describing right.
Old Feb 25, 2011 | 05:39 PM
  #33
1WILLY1's Avatar
1WILLY1
yes thats exactly what im describing---i dont believe all sc's do this --------my caqr does not throw codes and the dealer couldnt give me any answers either---the main thing is my car seems to be running fien but i still dont believe the light is supposed to stay on like that ---if i get any answers ill be sure to let you know
thanks man
Old Feb 25, 2011 | 05:48 PM
  #34
brad11140's Avatar
brad11140
Yeah I don't know man. Seems normal to me. I don't have any codes stored and it runs good.
Old Feb 26, 2011 | 04:06 PM
  #35
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Just a another update....
All is well and good in the SC community in my garage finally.
I have done the following things to determine one or more problems. I have cleaned the MAF, replaced TPS, inspected both caps, rotor button, wires, and plugs, pulled the throttle body and recleaned again, did the Fuel ECU bypass, lastly replaced all of the driver side fuel rail injector seals and rubber orings. The final results was a purring smooth running SC again. I think it was a combiantion of a dirty IAC and throttle body and TPS out of adjustment. It eventually ran little high on the initial idle, but now in all gears is silky smooth. It runs well again. Idle is 750. It does still show DTC code 31, which is the right front speed sensor, this was causing the trac, Check Engine light, and the Trac/Off to be lit. I have ordered another one and will delete that problem. Thats why my trac never worked properly according to the PDF file and the symptoms.
Let everyone know, keep everything clean and if you have a BFI as I do, keep an eye on the filter even more. If that makes any sense.
Thanks for everyones help on this. I will help any out if needed, or experiencing the same problems.
Old Feb 26, 2011 | 04:59 PM
  #36
1WILLY1's Avatar
1WILLY1
glad to hear it------enjoy your car ---im sure you will
Old Oct 27, 2018 | 01:14 AM
  #37
5thwardgs4's Avatar
5thwardgs4
Default Mines oit
Originally Posted by ThomasGS4
Why the hell did you take the CEL bulb out of your cluster?
Mimes out too
Subjug4tor
Jul 6, 2020 03:15 AM
LoudonMan
Feb 13, 2019 05:53 AM
SewWhat
Jan 10, 2014 12:14 AM
jarrard
Jul 11, 2011 11:33 AM
tonycky
Maintenance
Mar 14, 2004 05:21 PM
