Reverse wires?
For anyone who has done a swap/electrical themselves I'm wondering if you can help me out. Need to pass safety inspection but my reverse lights dont work, also the windshield washer fluid squirter doesn't work after the swap.
If anyone knows how the reverse is wired either threw the tranny or shifter wiring it would be great!
Not sure for your newer year model, but my auto was in the big plug on the transmission. Look here halfway down. This is my favorite site to link, it seems.
http://www.mkiv.com/techarticles/aut...spd/index.html
Yea when I did the manual swap, two wires had to be cut out of the big auto trans plug and soldered to the W58's reverse light wires. I can't describe exactly which wires from the auto plug but it was two wires on the far side of the plug.
https://www.clublexus.com/forums/per...thread-20.html
If anyone else is looking for this info I found it above, On my plug the the wires are yellow/green stripe, and solid blue.
The yellow I believe is power runs to a body plug, and the solid blue ties to some other blues and goes to ECU, I believe thats ground
Now if anyone can help me power the washer squirter so I dont have to trace it back to the steering column
kolessc400
Feb 6, 2016 04:19 PM
Anomaly
Dec 28, 2005 12:06 AM
