how much boost
Old Dec 24, 2010 | 05:08 PM
lexforlife's Avatar
lexforlife
actually using gte pistons on a na head is almost as bad as it relates to quench .. the best would be gte pistons with na hg...but from the research and testing my tuner has done ge pistons with tt hg is perfect for up to 30 ish psi
Old Dec 24, 2010 | 10:16 PM
good2go's Avatar
good2go
I thought that was what I just said
Originally Posted by good2go
... As far as quench is concerned, if you need to go lower compression than the TT HG provides, it's better to go with the TT pistons instead...
Old Dec 24, 2010 | 10:17 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Gte pistons + na headgasket is theoretically the best for maintaining the proper squish, but it does not lower the compression as much as the headgasket and costs many times more to do.
The only things i would do would be just tt headgasket (i actually did this), or stock high compression + methanol spray, or stock high compression + E85. all 3 will give u good power, prevent detonation, and not kill the wallet.
Building the block is overkill under 600 hp. if i blow a stock block I can just drop another one in.
Old Dec 25, 2010 | 01:03 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
I would use ALL of the boost!
On a more serious note, you should be fine on 16 psi I'd imagine. I wouldn't go over 20 though without upgrading some stuff.
Old Jan 2, 2011 | 07:02 PM
Prowler217's Avatar
Prowler217
ok. cool. yeah.. we are doing 18lbs.. i am trying to stay under 500 for the w58. i heard too close and they are no good.
I need some info and help. I have done the searches. but I am trying to go distributorless but I was told by my installer i am missing something.
I have:
Stand alone
vvti ignitor
vvti coil packs
crank sensor
Block off plate
GTE cams.
what am i missing or is there a link to an instructional set up?
Old Jan 2, 2011 | 07:34 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
there are a couple different ways to go coil on plug on a non-vvti 2jzge.
normally the distributor is the cam and crank sensor.
if you want to use gte cams, they do not have the gear for the distributor on exhaust cam.
part of it can be remedied by using a Gte oil pump for the GTE crank sensor setup.
the other part is not easy because the na head has no spot for a GTE cam sensor.
some people drill the hole and weld a fitting to the na head to make it like a TT, or use an actual TT head (the vvti 2jzge has this fitting also).
some people have also made a custom hall trigger setup. there is no diy yet for the 2jz.
If you just use 2jzge cams though instead of GTE ones, you can run a CPS in place of the distributor (or even use just the base of the distributor) and get your cam/crank signals. it works effectively and CPS costs under $50. you would just need the standalone, the vvti ignitor, and vti coilpacks, and the cps or distributor as the sensor, pretty much everything you have but you cant use the GTE exhaust cam.
here is a write up.
https://www.clublexus.com/forums/per...coilpacks.html
Old Jan 3, 2011 | 05:33 AM
k93's Avatar
k93
With all this info i just need someone to point me in the right direction, I just had a supra vvti TT auto installed in my 2000 sc300. Alllllll I wanted for Christmas was 400/450 safe horsepower. So far everything is stock except for the koyo radiator and fmic. open for any info and thx you guys know your shiiiiiiiiiiiiiiiiiit
Old Jan 3, 2011 | 08:01 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
you should start a new thread. sounds like you need some bpu mods, get a downpipe and a boost controller and raise the boost to just below fuel cut. search BPU and things like BCC (boost cut controller: if you want to go past boost cut). there are lots of ways to do all this.
Old Jan 3, 2011 | 09:11 AM
k93's Avatar
k93
Just had the down pipe , boost cut /speed cut done . Ordered a boost controller , so sounds like I'm on the right track . I believe I'm going to need to due fuel line modifications. Was told yo fore go most of those electronics to get a aem...
Old Jan 3, 2011 | 02:41 PM
Prowler217's Avatar
Prowler217
Thanks for the info Ali sc3 I have that cps sensor also. So just leave out the 2jzgte cams right . Basically.
Old Jan 3, 2011 | 07:07 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
yup, the n/a cams are actually pretty decent, and you can get longer duration ones as well.
axis730
Nov 16, 2016 06:54 AM
Juiced2jz
Sep 7, 2015 04:50 AM
JZITALL
GS - 1st Gen (1993-1997)
Aug 15, 2015 03:48 PM
ScottURnot
Lexus Vehicles Classifieds
22
Dec 1, 2007 02:56 PM
