SC- 1st Gen (1992-2000)
JDM Aristo chargepipe with USDM turbos?
Old 12-22-10, 01:58 PM
adl16v
adl16v's Avatar
Question JDM Aristo chargepipe with USDM turbos?
Hi I have searched and googled but really didn't find a good answer.
I am planning on doing a Aristo swap soon on my 95 sc300 5spd. I have been buying little things I might need for the swap and came across some usdm turbos locally(attached pic). As you can see in the pic they have no top hardpipes(chargepipes) and dumptube(side holes)? Question is when I get the aristo swap can I fit on the JDM hardpipes onto this USDM turbo setup? From the looks of the setup what else ould I need to bolt-up to the JDM engine?
I am also trying to avoid fabbing up a custom downpipe for the JDM flange abd would rather have non-ceramic turbos.
Old 12-22-10, 02:30 PM
RawkusX187
RawkusX187's Avatar
Charge pipes are the same the only difference is the bov are setup different. Downpipe would not work cause exhaust valves are shaped different.
Old 12-22-10, 03:21 PM
adl16v
adl16v's Avatar
cool thanks so I should be able to swap over the charge pipes no prob? as for the downpipe I just plan on getting a 3" aftermarket for a supra.
Old 12-22-10, 07:39 PM
RawkusX187
RawkusX187's Avatar
Yes charge pipes bolt on and for the dp you will need a aristo dp if is the jdm turbo's. Mkiv is for USDM twins
Old 12-22-10, 11:02 PM
adl16v
adl16v's Avatar
cool thanks I will be picking up those usdm twins tomorrow.
Old 12-23-10, 05:40 AM
RawkusX187
RawkusX187's Avatar
So you should be good with everything.
Old 12-23-10, 08:49 AM
97-SC300
97-SC300's Avatar
Who makes an aftermarket downpipe that can be used on the jdm aristo swaps?
Old 12-23-10, 11:56 AM
adl16v
adl16v's Avatar
heard its hard to find one made for a aristo. Most people fabricate the supra one to fit onto the aristo, or some modify the MK3 downpipe I hear but im not too sure
Old 12-23-10, 05:11 PM
RawkusX187
RawkusX187's Avatar
You got it! Aristo are rare in the states but I'm not sure it will work on a SC body. Muffler shops can fabricate a flange for it but I wouldnt really mess with Aristo turbo setup.
Jooee
GS - 1st Gen (1993-1997)
03-13-13 07:46 AM
S2dannyKeo
Performance
15
08-18-12 11:20 PM
soarer13oy
Performance & Maintenance
11-27-09 06:52 PM
teknoboi
01-05-09 04:37 PM
gotparts?
Performance
25
06-24-07 10:26 AM
Quick Reply: JDM Aristo chargepipe with USDM turbos?
