Front Lower Control Arm Bushings
Kinda new to the site. Thanks! Did you put yours on yourself?
Yes, I installed them myself. It's really not all that difficult a job unless you've got a rust belt car, then the bolts can be a real b**** to get off. But either way (bushings alone or new arms with bushing already in), you're gonna have to remove those bolts. I highly recommend looking around here a bit and doing your research; there's quite a few threads on this topic, including a DIY with pics. G/L
Thanks for all the help.
yip exactly wat good2go said...
to change the control arm bushings alone is a little involved.. the bushings would need to be either pressed out or burned out. messy stuff and a lot of work.
again my opinion, save up for new supra arms.
FuMoFFuTT
Jun 17, 2009 07:49 PM
MoogieBoogie
Feb 26, 2004 12:17 AM
