speedometer and odometer stopped working
Old Nov 22, 2010 | 01:03 AM
RX7 RAGE's Avatar
RX7 RAGE
Default speedometer and odometer stopped working
Does anybody know what things I have to check? I have a 2jz-gte swapped car with he v160 6 speed getrag. It worked for a few weeks then it just quit on me. The speedometer stays at "0" and the odometer doesn't go up in miles at all.
Old Nov 22, 2010 | 06:26 AM
99SC42's Avatar
99SC42
So it was working after the swap then stop working? right
Did you check the wiring at speed sensor? maybe the connection got loose.
Or you might need a new speed sensor i will check the wiring first before I start to spend some on parts.
Old Nov 22, 2010 | 07:50 AM
RX7 RAGE's Avatar
RX7 RAGE
Thanks, I'll check it out.
Old Nov 22, 2010 | 09:40 PM
Carfreak70's Avatar
Carfreak70
I'm thinking speed sensor too. Definatly would want to check that out man. Not much else it could be...
Old Jul 24, 2020 | 06:07 AM
JabobJeff's Avatar
JabobJeff
This video explains the 3 simultaneous symptoms others have had and shows the process of how it’s fixed. Hope this helps everyone who may run into this issue.
3 issues are:
1. 1. speedometer not moving
2. 2. odometer digital display is blank
3. 3. shifting is erratic while trying to accelerate
CatManD3W
Sep 14, 2019 07:08 PM
tavarish
Aug 16, 2008 07:12 PM
sc250tt
May 28, 2007 06:43 AM
nardy
Jan 8, 2004 02:56 PM
