Extended tie rods more angle ??
Old Nov 14, 2010 | 06:50 PM
snakehead's Avatar
snakehead
Default Extended tie rods more angle ??
Who has tie rods that are extended out for more turning angle in a drift ??
Is it worth the upgrade ?
I searched and could not find the thread about where MAX designs a extended end link for about $400 , Is this price for both tie rods also ??
Who has them and how do you like it. ??
Old Nov 14, 2010 | 08:23 PM
frankdms's Avatar
frankdms
It is the inner tie rod that has a 7~ish mm spacer allowing the rack to travel that much more. The inner tie rod stops when it goes into the rack, the "spacer" which is smaller than the tie rod goes in 7~ish mm's into the rack giving the reck a little bit more travel. If you are looking for turn angle have your knuckles shortened. Here is a link about mine.
I would do a search for JIC tie rods (inner's) They work well.
https://www.clublexus.com/forums/dri...t-project.html
Lucky you, HPF has a set on sale for 156$ http://www.horsepowerfreaks.com/part...od_Ends//12747
Rozay604
Sep 1, 2023 03:54 PM
crcuevas
46
Jan 6, 2023 12:40 PM
jdanielca
Sep 6, 2018 05:50 AM
crazy8ship
Mar 21, 2016 08:04 AM
iridebmx
Feb 18, 2013 07:40 PM
