OBD II ECU help
Old Oct 30, 2010 | 04:20 AM
JesLet's Avatar
JesLet
Default OBD II ECU help
I am in a process of converting my '97 SC300 with R154. I know all OBD 1 cars can retain the auto ECU without the CEL light coming on.
Different story with OBD II though, If I keep my auto ECU I will have a CEL light. In order to fix the CEL light, I need an OBD II manual ECU ( I can source one from 1996 manual SC300). Now here are my questions:
1. Will a 1996 manual ECU will work on my car or I have to get one from an MKIV?
2. If the 1996 ECU will work, is it ideal to use this ECU for 2JZGTE non-VVTI swap?
Old Nov 1, 2010 | 05:40 AM
stockhatch's Avatar
stockhatch
I am pretty sure the 96 ecu will work on the manual swap(you may need a 97 specific, but I doubt it)...Even so, the 2JZ-GE ecu won't run the 2JZ-GTE engine. The only option to run a manual, OBDII swap without a CEL would be a USDM Supra ECU. That also means converting to MAF, or at least a VPC. It may also involve some EGR trickery to prevent a CEL if you are running a JDM non-EGR swap. Regardless, there is going to be some wiring involved.
mikef
Oct 27, 2013 03:25 PM
jwin
Sep 18, 2012 10:16 AM
xsc2jz
Jun 28, 2012 08:45 PM
Bleak
Nov 7, 2011 06:31 AM
DasBach
May 4, 2007 07:10 AM
